20 Most Recent
Mitsubishi MSZ-A12NA Air Conditioner Questions & Answers
I have a Mitsubishi mini
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
My unit is working properly; however it is
Try to blow into the drain line from outside to clear the line if you don't want to take apart the evaporator. Also check for level of evaporator. If this does not help you your unit could be low on charge and could be starting to freeze. More likely to be a drain problem. hope this helps you.
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
