20 Most Recent Dynex DX-LCD19-09 19 in. LCD TV Questions & Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dynex... | Answered on Nov 27, 2015
plug the main unit in the tv
Dynex... | Answered on Jun 24, 2015
0281,0288. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dynex... | Answered on Dec 28, 2014
If the set is running in some type of component mode or digital component mode, there is no adjustment for color or tint.
Dynex... | Answered on Oct 21, 2014
Just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This must make the TV to a hard reset. If no other problems to the set's internal circuit boards, it should work properly. If it does not help you, make sure that the main board to this TV is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Dynex... | Answered on Jul 08, 2014
Main board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Dynex... | Answered on Apr 04, 2014
Adjust the contrast, color, and brightness settings. Make sure the video cables are securely connected. Make sure the correct video mode is selected.
Make sure the incoming signal is compatible. Make sure the antenna is connected correctly.
Check the closed caption settings. Some text modes can block the screen.
Dynex... | Answered on Oct 16, 2013
Increase the volume. Make sure that the sound is not muted. Make sure that the correct audio mode is selected. You can also try to power cycle the TV by turning the TV off and unplugging it for a minute, then plug it back in and restore system settings back to default. If the problem still persists, I would recommend bringing it back to the store to pursue repairs.
How is your TV setup--do you have a cable box, satellite, or basic cable? I would recommend going into the settings and running a channel search.
Press Menu. The on-screen display menu options with Setup highlighted.
Press RIGHT arrow to enter the sub-menu, then press DOWN or UP to highlight AUTO CH SEARCH.
Press ENTER or RIGHT arrow to start the search.
have you tried the screen control board on the back of the screen. were and how did it get wet??
Dynex... | Answered on Sep 17, 2013
check the ribbon cable that connects the screen to the mainboard may have a loose connection
Dynex... | Answered on Feb 03, 2013
Test: You might see a pic by shining a bright light against the screen. (Halogen can burn a spot if too close for too long like 15 seconds). If so, you probably have an inverter, backlight tube or coil/driver board problem. Some of thse units have a bad ground on the tube driver coil board which can be shimmed and/or tightened. Sometimes a simple car light tester (continuity tester with a 12v bulb) from casing/mount ground to any of the - side of the backlight driver coils will light the screen and reveal which tube is non functional. I leave one dome light running in such ground position one of my TVs at all times for regulation and night dimming.
Dynex... | Answered on Jan 20, 2013
Most of the time its not your TV its the TV stations signal. Unless you live like in a nursing home were there are a gang of cable boxes and there is an adjustment on the box it self. We have them in our faucilty.
Dynex... | Answered on Sep 09, 2012
Check and replace its main system memory IC.
Dynex... | Answered on Aug 31, 2012
Dynex DX-LCD19-09 19 in. LCD TV Logo
96 questions posted
Top Dynex Televison & Video Experts
Vitally Alcher
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
19 in not possible adjust color tint
  • Televison & Video
