20 Most Recent Samsung LN52A580 52 in. HD-Ready LCD TV Questions & Answers
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32 https://www.youtube.com/watch?v=eejE6O340EY Aug 22, 2011 - Uploaded by Jonathan Polis Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28 https://www.youtube.com/watch?v=dYHPKxijz1A
2/15/2018 7:38:08 PM • Samsung LN52A580... • Answered on Feb 15, 2018
Hdmi 3 quit working
If you put the input from HDMI3 into HDMI2 does the problem follow the input, or does it stay with HDMI3? If it stayed with HDMI3, check the connector visually for damage (cracks, dirt, bent connector). You may have to replace the board, or if you are really handy, the connector. If the problem moved to HDMI2, then look for a cable or device problem.
9/11/2013 2:25:03 AM • Samsung LN52A580... • Answered on Sep 11, 2013
Hdmi invalid format 1080p
9/11/2013 2:24:11 AM • Samsung LN52A580... • Answered on Sep 11, 2013
Flickering
For Anthony Pitt, The Samsung in your questiobn does not use the same power supply, I found one tip that says to check transistor Q802S on your power supply module, to insure the middle leg of the transistor in not broken from the transistor to the pc board. Thsi can cause erratic behavior. If the screen starts to behave after it's been on for awhile, your issue may be defective capacitors. Be certain none of the capacitors have raised tops. I have had intermittent issues with 46 and 52 inch screens. Failure occurs at the ribbon connector of the lcd screen and is only repaired by replacing the screen. I've found some repair tips on You Tube, but these have not been very reliable.
6/6/2013 7:42:17 AM • Samsung LN52A580... • Answered on Jun 06, 2013
Need schematic and/or block diagram for samsung LN52A580P6F
Go for a search in google, there are many who provide free schematic and service manuals.
7/15/2012 9:32:05 PM • Samsung LN52A580... • Answered on Jul 15, 2012
52 inch Samsung Flat Screen TV
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.4_1_2012_3_34_27_pm.jpg
4/1/2012 3:34:32 PM • Samsung LN52A580... • Answered on Apr 01, 2012
It takes about 5 mintes for my tv to actually turn
hello,
Cycling turn on off mostly from capacitors on PCB power board. Read my tips for cycling power on here. For Purple spot i think because capacitor efect i hope.
Good luck.
4/19/2011 10:50:40 AM • Samsung LN52A580... • Answered on Apr 19, 2011
2answers
Tv powers on and off with no picture . it has to
Look for capacitors on the power board that are domed on top. replace these.This almost always does the trick.
3/7/2011 10:09:30 PM • Samsung LN52A580... • Answered on Mar 07, 2011
My picture is to the
check the zoom settings and look for the option to move it to the right. this can usually be found on the same location for the aspec ratio
12/4/2010 1:41:34 PM • Samsung LN52A580... • Answered on Dec 04, 2010
My tv keeps going into power saving mode
its problem with mc.turn it off and unplug it for a while.it might reset
3/9/2010 7:17:18 PM • Samsung LN52A580... • Answered on Mar 09, 2010
My samsung ln46b610a5fxza picture started to have magenta and green and red vertical lines appear on the screen and now they won't go away
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
1/16/2018 12:19:22 AM • Samsung LN... • Answered on Jan 16, 2018
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/18/2016 3:00:54 AM • Samsung LN... • Answered on Nov 18, 2016
How do I troubleshoot my Samsung TV? I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
3/17/2016 10:45:02 PM • Samsung LN... • Answered on Mar 17, 2016
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
1/18/2016 3:39:48 AM • Samsung LN... • Answered on Jan 18, 2016
Samsung LN52A580 52 in. HD-Ready LCD TV Logo
20 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
need schematic or block diagram samsung
  • Televison & Video
