20 Most Recent Insignia NSPDP50 50 in. HD-Ready Plasma TV Questions & Answers
Hooking up a sound bar ? Does it have an optical output
Check the video https://www.youtube.com/watch?v=Z27WtBy4IUs If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/
3/12/2016 4:54:28 PM • Insignia NSPDP50... • Answered on Mar 12, 2016
Blinking Plasma TV. After being on for a while, it "blinks"; no displacement up or down of picture. TV "blinks" a couple of times every half hour or so (I didn't time it).
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/12/2015 12:03:36 PM • Insignia NSPDP50... • Answered on Nov 12, 2015
Insignia NS-PDP50 Plasma tv HDMI inputs are inoperative
First of all, make sure that the hdmi BLOCK setting is correct. This prohibits both hdmi inputs and the DVI from working. I didn't even know they existed so I replaced the YSUS board and then I found the settings were my issue all along. If the settings are correct then the most likely culprit is the YSUS board part number: BR36223601. It is a compatible card for your TV. There are several suitable subs for this board and it is a snap to replace. I found a like new board that works better than my original board for only $25.00. The heck with those rip offs for prices up to nearly $300... Good Luck.
6/6/2014 11:41:37 PM • Insignia NSPDP50... • Answered on Jun 06, 2014
Why are both hdmi inputs not workingInsignia NSPDP50 TV
How do you know they aren't working?
5/4/2014 5:49:27 AM • Insignia NSPDP50... • Answered on May 04, 2014
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs. • Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
1/8/2013 5:42:05 PM • Insignia NSPDP50... • Answered on Jan 08, 2013
I have a plasma NS-PDP50
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter..
8/30/2012 11:06:11 PM • Insignia NSPDP50... • Answered on Aug 30, 2012
Insignia 50 inch 1080 plasma - Picture only shows about 3 inches at the top of the screen
Several possible suspects include: power board, main board--first step is test voltages coming out of power board--------remotely possible also is the display itself (panel which is screen unit) if it turns out to be that it is fatal.
6/11/2012 2:36:18 PM • Insignia NSPDP50... • Answered on Jun 11, 2012
INSIGNia NS-50P650A11 SHOWS RED LIGHT BUT A BLANK SCREEN
That problem is usually have 2 causes..Its either power supply board or main board..Please take this steps on how to determine the problem:1. Open the back cover.2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..4. If the power supply output is normal..The problem could be on the main board...5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..Hope this solution will be helpful..Thanks for using fixya...
6/7/2012 11:26:50 AM • Insignia NSPDP50... • Answered on Jun 07, 2012
When i turn the tv on it cuts right off
There is some shorted component/s on the main baord to this TV. Seek tech assistance. This is a very skilled work.
6/5/2012 1:48:21 PM • Insignia NSPDP50... • Answered on Jun 05, 2012
Tv was on then had color spectrum full screen then
there are several board in plasma tv which can cause this kind of problem. there is Y board, there is X board & the plasma panel itself may be faulty. u need to replace both boards one by one to get the problem solved. if replacing both boards not solves, then u have to replace the PANEL which is a costly repair.
9/26/2011 7:41:08 AM • Insignia NSPDP50... • Answered on Sep 26, 2011
In the back of the tv thier is no place to put the
The Video 1 input on the rear is the input that has composite video in(yellow). you can find the manual below.
http://insigniaproducts.com/cms/documents/NS-PDP50HD-09%20UM%20EN_SP_FR.pdf
Good Luck!
8/31/2011 7:41:48 PM • Insignia NSPDP50... • Answered on Aug 31, 2011
When first turned on, TV
I have not repaired this brand of TV. I would say my first hand of repair, is needed in the signal board. This board is the one with all the RCA slide in jacks and RF connections (Tuner, cable line screws into this). You may have bad capacitors, electrolytic or surface capacitors. Replace capacitors or exchange for a new Hope this clues you, into describing your problem to your local TV shop. Thanks for asking and show all hands of support!
8/15/2011 12:25:47 PM • Insignia NSPDP50... • Answered on Aug 15, 2011
I have a Insignia NSP501Q-10A.
It went for around 1300 when it was new at Best Buy. By now I would say the T.V. is probably worth about 600ish, just because of its age and resolution. If it's getting hot just being plugged in then I would say that there is a problem with it. There is no reason for it to overheat without it actually being turned on, which makes me think there may be a short in there. I would unplug it for now just to be safe. Here is a list of replacement parts for the T.V. The power supply goes for about 149 and the cooling fan goes for about 50. But with the clicking sound it makes me think that there is something wrong with the power supply. With parts and service it would probably cost around 300 or more to have someone else fix it.
5/5/2011 6:09:44 PM • Insignia NSPDP50... • Answered on May 05, 2011
Insignia NSPDP50 50 in. HD-Ready Plasma TV Logo
44 questions posted
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
insignia ns pdp50 plasma tv hdmi inputs
  • Televison & Video
