20 Most Recent Imation MLTD3222 32 in. LCD TV Questions & Answers
Power supply issues - I bet bad capacitors 'dried out' .
A good servicer should be able to fix it for you.
Imation MLTD3222... | Answered on Nov 19, 2009
Your question lacks detail, can't help.
Imation... | Answered on Mar 15, 2019
that specific model does not show up on their site but, this manual should have similar actions. Check it out
http://support2.imation.com/downloads/mrx/MK/MKS8590/MKS8591_Users_Manual.pdf
Imation... | Answered on Jan 02, 2015
I had the same problem until trying the latest drivers from DisplayLink for the Mac. You can get them here:
http://www.displaylink.com/support/mac_downloads.php
Imation... | Answered on Oct 30, 2010
You can't. Only basic controls can be done from the set itself unless you can get into Settings.
Google
make model replacement remote
companies now sell facsimile remotes which are identical to the original.
Televison &... | Answered 5 hours ago
Input source HDMI3 format is not recognized. Try selecting a different input source or connect a known good HDMI device to the HDMI3 input.
If you normally watch local broadcast TV from an antenna you need to change the "SOURCE" input to ANT (ANTENNA).
Televison &... | Answered 10 hours ago
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Televison &... | Answered Yesterday
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
https://electrohelponline.blogspot.com/...
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Imation MLTD3222 32 in. LCD TV Logo
Popular Tags
5 questions posted
Top Imation Televison & Video Experts
Marvin
Marvin
Are you an Imation Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Imation Televison & Video
Most Popular Question
no picture but sound when turning tv
  • Televison & Video
