20 Most Recent
Initial HDTV-320 32 in. LCD TV Questions & Answers
No signal for HDMI or DVI
Hi, what device or devices have you tried to connect through those ports? Were they working prior to this problem?
How do i put it to play dvd player
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
2Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
4Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
5Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Car Tuning
Recently moved to another city,
Hi my nameis Mike Houston of DISH Network and I was going over your post and see youmoved and lost the remote. We have what we call a Power Scan for the DISHNetwork remote; it will allow you to get the code to the TV. http://www.dishnetwork.com/SupportSection/power-scan-instructions
The tv turns off on
hi,
possibly sounds like a heat dissipation issue.(dusty ) could try a small fan pointed towards the back of the set untill you can get it serviced. if not then most likely the light source is going out. either way its going to have to be serviced soon. you could try and take it apart and dust it out with an air compressor if your mechanically inclined, google the name brand for disassembly instructions and light parts LCD's have a flourescent bulb in them. if you can get it out rather than having to take the whole set in, you just saved youself a you know what load of money!
jm
jm
Volume is stuck, buttons on tv wont lower it and
Sometime if a button is stuck it can lock up the processor and cause all the buttons connected to it to not function. Insure all buttons press and release normally. If all buttons appear to press and release in a normal fashion a trip to the repair center may be call for.
