20 Most Recent
Panasonic TX-32LX1F 32 in. LCD TV Questions & Answers
Hello technicians! i have a
Since you have backlight and audio is good, this is definitely an LCD controller(T-Con) problem. Its a small board that is inexpensive(costs about 30-50$). Replacing it should resolve the problem. Let me know if you wish to do it yourself.
Sai.
8/25/2011 2:55:03 PM •
Panasonic...
Answered
on Aug 25, 2011
When switching panasonic tv on it goes into
It is for sure that your set has encountered a fault in the power section in the main board. There could be either a failure or a break in the circuit. So first of all open and check the main power board for any signs of dry soldering joints. Use a good soldering iron and a good light to probe. Solder all possible areas specially ones closer to the power resistors and drives. next check the +B voltage, trace it or disconnect from the ddrive to confirm the failure. You must use a good multimeter to check from the power section which is working and is cutting off due to a failed feedback. If not familiar do not attempt but take help. I hope you can decide and try. Good day
7/29/2010 4:49:24 AM •
Panasonic...
Answered
on Jul 29, 2010
Problem with panasonic tv
It is usually caused by problems from lead solder that sometimes does not connect, so there are some points of the components that are not connected with lead solder to the circuit. if it appears vertical line means from the IC (integrated circuit ) Vertical, you can solder all the points in the IC ( Integrated circuit ).
7/23/2010 12:06:47 PM •
Panasonic...
Answered
on Jul 23, 2010
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions.
How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM •
Panasonic...
Answered
on Feb 17, 2024
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
iFixit
https://www.ifixit.com > Answers > View > F60+error...
Oct 8, 2014 - Ron, F60 is a general error code usually related to a
failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer
https://www.justanswer.com > Electronics Question
Jan 5, 2018 - The
F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum
https://www.avsforum.com > threads > panasonic-dmr...
Oct 26, 2014 -
F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times
https://www.eetimes.com > another-capacitor-failure-a...
Jan 21, 2019 - An online search revealed that
F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS
2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer
https://www.justanswer.com > recorders-and-players
Dec 23, 2012 -
F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ...
1/30/2024 3:40:50 AM •
Panasonic...
Answered
on Jan 30, 2024
Need to access menu on Panasonic viera without remote
If you need to access your Panasonic television's menu and you don't have a remote, then your best option is to use the physical buttons on the television itself. There is a MENU button, often on the back of your Television.
12/11/2023 9:37:19 AM •
Panasonic...
Answered
on Dec 11, 2023
