20 Most Recent Polaroid TLA-04011C 40 in. LCD TV Questions & Answers
LCD Display Panel/screen is damaged. Replacement of the LCD Panel is only solution of the problem. By the way, cost of LCD display may be higher than the cost of new TV. Check you local market for the price.
Polaroid... | Answered on May 26, 2017
Polaroid TLA-04011C
You can get a service manual from;
http://www.polaroidsupport.com/polaroid/docs/TLA-04011C_TLXB-4011_TLXB-4241_ServiceManual_20070613.pdf
This will give more diagnostic flowcharts etc. Could be useful in the future also.
Polaroid... | Answered on May 22, 2017
Polaroid TLA-04011C
You can get the user's guide from;
http://www.polaroid.com/service/userguides/ce/lcd_tvs/tla04011_ug_en.pdf
You can get the quick start brochure from;
http://www.polaroid.com/service/userguides/ce/lcd_tvs/26-47_tlxb_qs_en.pdf
The information is oriented to service but you can get infomation on operation
starting on page 10.
One place you can get the remote from;
http://www.remotes.com/
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Polaroid... | Answered on Jan 19, 2016
use the buttons on the side of TV
Polaroid... | Answered on Jan 18, 2016
HI, your video Connect your Audio cable ( white-red) output from dvd to tv in. Then connect your video output ( yellow) to tv video in. If you have Pb Y R in /out , just connect them accordingly to enhance the video.
Regards
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Polaroid... | Answered on Oct 13, 2015
take a look at the link below, hope it is useful to you, God preserve you from the grandkids!!
Polaroid 4011 TLXB 40 LCD TV Service Manual
http://service-manuals-schematics.com/index.php?id=Polaroid
Polaroid... | Answered on Jun 17, 2015
I had this problem once. what I did was switch the caption to a different type and the caption went away. try it if you want.
Polaroid... | Answered on Jun 10, 2015
Probably Not. Since most universal remotes will only be good for certain functions,i.e. Volume, Channel etc... not all the features of the original remote. You can try to do it manually if there is a Menu function on your TV.
Polaroid... | Answered on Jun 03, 2015
tried with other files doesn't work like mpeg4, divx and jpeg?
Polaroid... | Answered on Apr 17, 2015
Try a number of repair shops. Try to find out about their reputation. Out of warranty?
Polaroid... | Answered on Apr 01, 2015
There may be an issue with "cold" solder joints on the power supply board, or there may be a failing component on that board as well.
Some things to look for also are bad solder joints particularly on the fuses of the inverter board or boards depending on production run. Those are going to be rectangular items marked with "8A" on them near where the multiwire connector attaches to that board under the plastic cover. As well as any bulging electrolytic capacitors. Since there usually more than one in parallel if one shows as bad- replace them all
A can of cold shot help locate the specific area or component of the 24 volt section of the power supply that is the issue.
Polaroid... | Answered on Jan 19, 2015
Take a flash light and point it close to the screen . do you see a picture.
You have a bad back light or inverter the powers the back light. in any rate here the unit will need a repair shop because these are hard to get to you have to dig.
let me know ether way/
thanks for asking your questions please do rate and leave feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Polaroid... | Answered on Oct 13, 2014
Polaroid TLA-04011C 40 in. LCD TV Logo
215 questions posted
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
much will cost me rewpaired
  • Televison & Video
