20 Most Recent Polaroid TDA-03211C 32 in. LCD HDTV Questions & Answers
I HAVE A 42" Polaroid LCD TV (TLX-04240B) that i
First, I doubt that the power supply and MB are "connected", so they likely lied to you. As far as parts go, you can get them on Ebay, probably for around bucks total for the power supply and MB. This is important, Just because the model number on the TV matches the model number on the part, it doesn't mean it is the right one...the manufacturers sometimes use different boards on the same TV's. So make sure you are looking at the numbers on the boards and that they match before you buy it. Honestly though, you never know what you are getting on ebay as far as used boards and power supplies go, by the time you pay for shipping ETC you are going to be probably 150 to 200 bucks into it...and it might not work, or it might work for a while then the used parts go out as well. Best Buy has a 43" sharp LCD TV, smart, built in Roku...for 269. You might be better off to spend the extra 50 to 100 bucks and just buy a new TV, and definitely better off buying a new TV than paying some scam artist 400 bucks to fix a TV. Either way, good luck!!
1/4/2018 3:58:19 PM • Polaroid... • Answered on Jan 04, 2018
0answers
TV takes 20 mins to turn on...1st screen ia black
Definitely take the TV for repairs.
8/28/2017 3:37:18 AM • Polaroid... • Answered on Aug 28, 2017
My Polaroid 32" LCD TV just stopped working after only 7 months!!
they use an inferior brand power board. the power board you will fined it has alot of capacitors that will need replacing. in worst case you will need a replacement power board. if you replace the capacitors use 105c types and not the same brand that are on the board these capacitors are like grade F capacitors, really cheap.
6/5/2017 9:15:02 PM • Polaroid... • Answered on Jun 05, 2017
My sound suddenly stopped working on the 32 inch
Mine did that and I went and punched menu and reset the TV back to factory settings and it's ok now.
5/24/2017 1:05:43 PM • Polaroid... • Answered on May 24, 2017
Can't get universal remote to work for polaroid tv/dvd combo
read here http://www.fixya.com/support/t225581-code_polaroid_tv
5/19/2017 9:14:09 AM • Polaroid... • Answered on May 19, 2017
2answers
Black screen. Does the bulb need to be replaced?
no bulb in lcd silly/does it flash when powered on its
the ctrl/lvds controls back lighting buddy
12/13/2016 8:15:15 AM • Polaroid... • Answered on Dec 13, 2016
Panasonic 36" tv model TDA 03211c
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/20/2016 6:52:21 AM • Polaroid... • Answered on Sep 20, 2016
2answers
About recent question.
Unfortunately, some of the "Experts" here really aren't. Everyone that answers a couple questions is listed as an "Expert" and it doesn't matter if their answers are worthless! "The Knight" has over 64,000 questions answered, so I question his or her credibility. "The Knight" didn't even bother to warn you that a TV has hazardous voltages even when unplugged. It's usually limited to the power board, but still you should have been warned. Your problem could have been the T Con board, but it also could be your display or another control board if yours has another. There's also a smaller chance that part of the power supply has gone bad. Unfortunately, you'll have to get a TV repair shop to check it.
9/6/2016 12:12:34 AM • Polaroid... • Answered on Sep 06, 2016
The remote for our tv does everything but it won't turn it off or on. Is it the tv or the remote that's defective?
Most likely the remote. It's one of the most used buttons and the contact wears out. Buy a new remote and it's fixed.
8/13/2016 9:14:27 PM • Polaroid... • Answered on Aug 13, 2016
2answers
How to fix black screen on Polaroid 32" wall mount tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
11/7/2015 8:25:36 AM • Polaroid... • Answered on Nov 07, 2015
How do I fix my tv
child lock may b on c instructions
4/27/2015 2:47:11 PM • Polaroid... • Answered on Apr 27, 2015
Screen goes black, still have sound. Been researching for hours please HELP!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/23/2015 5:26:27 PM • Polaroid... • Answered on Mar 23, 2015
I have a 32inch Polaroid LCD TV and somehow my son switched it to black and white. Igot it bk to colour somehow but now he's done it again and I don't no how to get it bk?.
this is what I would try,,, unplug it from the wall socket for a min or so. and sometime u can hold the power button in for 30 seconds while the TV is UNPLUGGED . on some sets that resets the defaults.
1/7/2015 9:08:19 PM • Polaroid... • Answered on Jan 07, 2015
Polaroid TDA-03211C 32 in. LCD HDTV Logo
508 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
panasonic 36 tv model tda 03211c
  • Televison & Video
