20 Most Recent
Samsung LA22A450 22 in. LCD TV Questions & Answers
My tv takes time to turn on
There are a few ways to cure this problem:
- Do not turn off your TV
- Allow time for your TV to turn on before your programme starts.
- Ask someone else to turn the TV on five minutes before you come home and only turn it off when you're going out.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
How to turn off music when turning on tv
Yes it is possible. You should be able to set the melody to off, low, medium or high
I believe you can get to the setting by doing this:
- Press the MENU button to display the on-screen menu.
- Press the up or down button to select "Setup", then press the ENTER button.
- Select "Melody" by pressing the up or down button, then press the ENTER button.
- Select the setting you want (Off) by pressing the up or down button
repeatedly.
- Press the ENTER button.
- Press the EXIT button to exit.
You can find the manual here:
http://downloadcenter.samsung.com/content/UM/200804/20080401185600828_BN68-01507A-01Eng-0328.pdf
Page 24/25 is where it talks about the Melody setting.
White screen
Shorted chorma processor IC at main board. Contact any service technician.
Required Remote
If you wish to get setup codes, three digits, four
digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model
remote controls are given. Select the 'Timeslide' option from the drop-down
list by the 'Sidebar' at the display window. It will make search easy.
