20 Most Recent Sansui HDLCD1908 19 in. LCD TV Questions & Answers
Ouch. If you are lucky unplug double check cord connection at back. No help? Wire at plug end may have torn in the fall. Wiggle wire at the plug end if you get something the cord needs to be replaced. Otherwise, you may have major damage. A lightly used replacement may be less than a repair.
Sansui HDLCD1908... | Answered on Mar 06, 2015
i want sansui rimote codes
Sansui HDLCD1908... | Answered on Jan 02, 2015
Only a green screen is a bad symptom. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen shots to defective LCD panels are given. You can compare it to that of your TVs'.
Sansui HDLCD1908... | Answered on May 11, 2014
are you hooked up to cable? it you are then the problem most likely is in your cable box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sansui HDLCD1908... | Answered on Apr 22, 2014
2156,2152,2159,2123. Try these codes. For more information http://electrohelponline.blogspot.com/
Sansui HDLCD1908... | Answered on Nov 22, 2013
Ensure the power outlet is ok and if on doubt, check the TV on some other. If it does not work, the TV has some blown fuses or other board/component failures.
Sansui HDLCD1908... | Answered on Aug 13, 2012
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Sansui HDLCD1908... | Answered on Aug 07, 2012
call you digital cable provider
Sansui HDLCD1908... | Answered on Jul 23, 2012
its just the brand cause mine did it also... cause when mine started doing that i traded it in for the same one and it did the same thing... so i decided to get a different brand and it hasnt done it
Sansui HDLCD1908... | Answered on Jun 18, 2012
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Sansui HDLCD1908... | Answered on Nov 02, 2011
The simplest thing to do is contact your cable service. This mishap can be reset by them if you give them the information that they ask, they should be able to remove the block or even give you the password. All and all...call them!
Hope this helps ^_^
Sansui HDLCD1908... | Answered on Jul 18, 2011
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Sansui HDLCD1908... | Answered on Mar 21, 2011
Yes, you can either plug speakers into the back of the monitor in the orange colored slot. But in order for this to work, you must also plug the computer tower audio output into the Sansui's audio input port, which is located directly underneath the monitor's video input (where it is already connected to the computer). If that sounds like too much work, you could always just plug your computer speakers directly into the audio out of your computer tower.
Sansui HDLCD1908... | Answered on Mar 17, 2011
It will connect in the back of the TV. You will see a female socket under the lip of the RCA connections and RF connectors. This power cord is just like the computer power cord you already use! Thanks for asking and show a few hands of support!
Sansui HDLCD1908... | Answered on Mar 04, 2011
What was the voltage rating and the Current rating of the older fuse? And which fuse is it? THe main fuse or one of the pico fuses on the short protect circuit(that some tvs have)
Sansui HDLCD1908... | Answered on Jan 21, 2011
Sansui HDLCD1908 19 in. LCD TV Logo
60 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
ic 76931 5ap3 rimote codes
  • Televison & Video
