20 Most Recent
Sanyo 42 in. LCD TV Questions & Answers
Sanyo DP42410. Everytime i turn
I had to call Sanyo on this same problem, and I just wanted to help you out on this. When you turn on the the TV and it asks for home or store, chose home then do the channel scan. After the channel scan completes, switch to your tv source, hdmi1, then turn off the tv and back on and it should just go straight back to hdmi1. Let me Know if this works!
No pic, just sound
Hi, you have not specified if your tv is still conventional tb that uses crt, or lcd
I replace everything inside a sanyo dp42848. Power
Only for a little suggestion even when it has nothing to do with this to know ?
https://www.youtube.com/watch?v=t36YT7-5GTY but have you test those kind of fcc flatsheets by manipulating like for example pushing on it with a peace of towel on those sheets for a faultering test ? they can be dry out and come loose by direct sunlight or other cause by heating up over a time and it will become faultering.
Maybe it could be in cause of strange defects if you have service manual and all things measured do not use the new prints without heatsink it should allways on it if the same chipset is used if not modified , or you have bought a refurbished print because of the missing heatsink and metal cover?
I have a Sanyo 42
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
MY SANYO LCD TV MODEL 24 K 50 WAS OFF WHEN
Replace or have the powrer supply tested and eventually serviced.Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.So naturally you start your quest with the power board , which is the usual suspect.As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.Good luck!
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
https://www.
mydish.com/support/
remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
https://www.directly.com/.../
dish-network-my-dish-
remote-needs-
progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
dish-network-how-do-i-
program-my-dish-
re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
Fix a sanyo lcd tv model 42840 will not power up (?)
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
No power
Check on the power connection cables through from the sanyo TV to the current outlets. make connection firmer to grip on for suply flow. Power on TV once more shoudl have some positive effect than as before
