20 Most Recent
Sharp LC-C4655U 46 in. LCD TV Questions & Answers
I hit the tv and
You don't really want to ask the price of a replacement screen. It's bad for the heart ;-] You may want to do a quick check to see if you had any warranty that covers accidental damage. It would have been an extra pay thing at the store. That covers things like this otherwise this is classified as user abuse and not covered.
Usually it is much cheaper to replace than repair. Get a quote from the store or sony but you will probably find that buying a new tv is the cheaper way to go.
I have a Sharp LC-C4655U
Sir most of the tv today is auto volts try to check the voltage rating at the back of your tv if indicates 100 to 240 volts you can just plug it in you don't need a transformer. Feel free to send feed back good day and best regards.
I have my TV plugged
In order to get the picture to show on your TV through a raw cable, you need a Digital-Analog converter Box.
Alternatively, if you have a cable service, you need a cable provided by your cable company.
Will not respond to remote
is the remote your using is the original one....well try to check the battery and it's terminal sometimes it needed to be clean...check the infra red LED of the remote using a cellphone camera...focus the lens on the LED of the remote..press once any key if the light responds once its good but if you see blinking of lights your infra red LED needs to be replaced....but if your remote is good but still no respond on your tv..the tv problem may be from the remote receiver...try for a technical assistance for repair..nice day..
Power light comes on for about 30 secs, something
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Picture no sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
