20 Most Recent
Garmin zumo 660 GPS Receiver Questions & Answers
Garmin forgot pin
If you are talking about the security feature of locking the screen, simply return to the GPS coordinates of where you locked the unit and it should allow you to unlock it and reset the pin... That means if it is stolen or locked by someone else you are SOL. If you pay for it to be repaired by Garmin I think they can unlock it. No one else has figured out how.
http://www.poi-factory.com/node/38702
Downloading songs from an i-mac computer to a garmin zumo 660
I don't know for sure, but most likely the problem is that iTunes keeps songs in AAC format, and the Garmin wants them in MP3 format.
If that's the case, then what you need to do is this:
in iTunes, build a playlist of the songs you want to export.
Click on that playlist to show the list of songs
Click on the first song in the list, then hold SHIFT and click on the last song in the list so they're all highlighted.
Select the menu option "Make and MP3 copy". Apple keeps moving this option, so you may have to hunt for it, depending on the version of iTunes you have.
This should leave the nice-quality AAC versions alone, but also make MP3 copies of each song.
Copy the MP3 files to the SD card and try that in your Garmin.
Where do I put the memory card in garmin zumo 660
your 660 uses a micro sd card located in the battery area...see page 5 of your manual
HERE you can download your manual from that page if you do not have one...see pic below for the location of the micro sd card
bill
