20 Most Recent Xerox Phaser 6115MFP/D - Multifunction - color - laser - copyin... Printer Questions & Answers
What causes recurrent 1LT error message?
Normally when you get an image shift it's because something went wrong in the registration section. This model has a registration roller that is driven by a clutch and solenoid. A frequent problem on this unit is that the registration solenoid will stick open and cause the print to shift on paper and it can be intermittent. You can try clean the solenoid plate, otherwise you will have to replace, the part number is 121E26000.
2/10/2016 4:56:25 PM • Xerox Phaser... • Answered on Feb 10, 2016
What do I do when my xerox 6115mfp continues to display please wait?
More than likely a thermistor or thermafuse has blown Not to fret a whole bunch the good news is that it was protecting you and not letting a fire occur Bad news is that if you're not tech savy then a service call is in order. One way to verify is the heat rollers hot when it says stand by? is the main motor running the whole time>? It might just be on the fringe of it telling you it needs toner. a service code would be helpful. there's a slight chance they told you in the manual how to access the service mode. Sometimes a sensor detects a situation//now the issue is gone. and it just needs reset. this is a good money maker for copier repair companies. If it was mine,(repaired copiers for 24yrs) I would try what I said ,write down what you find and then get on internet for service mode or push this button and that button at the same time to get code or also how many copies are on it. I'm assuming you're a fix it at home if you can kind of person or you wouldn't be here. Worse case scenario, bite the bullet and call the big red X.~~ Hope this helps and give Fixya a bit of feedback on how it turned out ~~~>S
7/29/2014 10:40:26 PM • Xerox Phaser... • Answered on Jul 29, 2014
Everytime I print, I get
This sounds more related that in your printer settings on the OS are set to an incorrect size. Such an error would result.
Check the printer setup from whichever program you are using and make sure it is the correct size. 8.5" x 11"
I've seen abode reader for instance go to 8.5" x 11.5" resulting in an error.
Comment back with what your printing from (software)
FYI. Not very familiar with Mac but I'll see what I can do.
9/13/2011 1:32:31 AM • Xerox Phaser... • Answered on Sep 13, 2011
0answers
0answers
I have a Xerox 6115
The toner is positioned by the Toner Rack . The Rack Postioin Sensor 130E11800 needs to see it there. Otherwise it reports a toner problem.
Clean that sensor, or replace it.
If the Toner Rack isn't moving then maybe you need the motor or figure out what is mechanically binding that Rack.
Whit
Item, Inc.
8/17/2010 11:04:57 PM • Xerox Phaser... • Answered on Aug 17, 2010
What is the best color copy with low cost per
The best I've seen is Minolta magicolor series color laser printers, The next is the Samsung line of color laser MFP's, good color, long lasting consumables, fast prints.
9/15/2009 5:05:41 PM • Xerox Phaser... • Answered on Sep 15, 2009
Xerox Phaser 3600 printing 3 horizontal black lines across every page
Replace your toner cartridge with a known good one even if it's empty. If the lines are not present you know you need to install a new one.
5/10/2023 10:22:31 PM • Xerox Phaser... • Answered on May 10, 2023
Error 389.601.00
JM Liabo English only on Fixya please. We are a North American website and only converse in English. hello, I have a phaser 7800? the ignition it puts this code, I switched off and on again? the first switch after 5 seconds as indicated. Same thing, nothing, so I wiped the color sensors. The problem persists. What to do? Call for Xerox Service https://translate.google.ca/?sl=auto&tl=en&op=translate Fixes
Xerox Phaser 7800 - Error Code - PrintCopy .info
https://printcopy.info > model=Phaser+7800 Code: 389.601 ยท Description: RC Sample Block Fail-A1-In. During the A1 (fine adjustment pattern) and C patch detection, the patch at the MOB Sensor In side did . and more here https://www.google.com/search?q=Xerox+Phaser+Error+389.601.00 ..
7/1/2022 4:40:00 PM • Xerox Phaser... • Answered on Jul 01, 2022
Xerox Phaser 3260 Printer. I can't reset counter on it. Is there software to do that?
Question edited for clarity, full 'make model (what it is)'. check out the videos, however, it is a Xerox and they like to keep track of page counts because it is often part of the contract for lease or toner supplies on their machines. https://www.google.com/search?q=phaser+3260+printer+reset+counter ..
6/21/2022 2:10:48 AM • Xerox Phaser... • Answered on Jun 21, 2022
Xerox Phaser 6115MFP/D - Multifunction  - color - laser - copyin... Printer Logo
Popular Tags
16 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
image shifted down one inch or page
  • Office Equipment & Supplies
