20 Most Recent
Frigidaire Affinity AEQ6000WH Dryer Questions & Answers
Error Code E68 on frigidaire affinity dryer.
Frigidaire Affinity dryer model AEQ7000ESO error code E68 (stuck button). Sometimes a 'stuck button' code really is a stuck button. I took the circuit board off the front panel.On the back side of the front panel, each button has 3 short plastic posts, 2 on one side and 1 on the other.The center part moves to push a longer piece that contacts the circuit board. When I push the top of a front stadium-shaped button, the center plastic piece moves too far, touches the short post, and sticks (maybe due to age). When I push the bottom of the front button, the plastic piece goes far enough to contact the circuit board and not far enough to touch the short post. To prevent a stuck button, we now press the bottom of the front buttons.So far so good. If it happens again, I plan to shave or file a little bit off the top edge of the post to give it more clearance. 1st photo: pencil points to stuck parts. 2nd photo: unstuck parts, 3rd photo: the front of our dryer.
My dryer quit working this morning. The light and
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Replacing the heat element on
Hello Timothy Johnson - Generally qualified technicians often perform complicated part replacement such as this. If I was in your position, I personally recommend contacting a professional to accurately diagnosis the precise issue before investing in parts that may or may not be the root cause. You can often locate a certified service provider through the manufacturer website.
E 64
Hello christinwogo - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
