20 Most Recent
Sanyo Katana LX Cell Phone Questions & Answers
Retrieve Katana LX contacts
Hi Dear..If the Charging slot is broken the you should buy the one alternate charger c
hina made charger in that charge direct you charge you battery, after charge the batter plug-in and transfer all contact in your sim card. after that your Sim card in you other mobile you can find your all contact. Thanks to Visit on Fixya .
Unlock code
hi,i had the problem once with this model then i unlock my mobile with this unlocker site http://www.mobile-unlocker.com/..go here and select your model,network provider name,country...then they give you instruction to unlock you mobile....
Can a broken **** phone be repaired?
It depends on how it was broken. If only the case is damaged, most shopping centerkiosks have replacement shells - if any of the internal circuit boards are damaged, you will want to send the unit in for replacement. If the warranty is up, you're looking at a new phone. The cost of electronics repair is often more than the device itself.Car Accessories
I forgot the unlock code on my Sanyo Katana lX...
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
I have read past advice
As with all mobile phones there are multiple ways of transferring pictures between them. Mostly people want to go the complicated way of doing things. There are basically three simple methods of transferring pictures and sounds from mobile devices to PC's.
First use of bluetooth: Most mobile devices such as your comes with a bluetooth all you have to do is enable you PC bluetooth if available or purchase a bluetooth accessory for your PC and you can easily transfer the pictures just like sending to another mobile device.
Secondly: You can make use of the data cable which came with your device. But in this case you have to first run the disc which came with your unit on your PC to install the driver for the phone. Then you connect the phone to your PC through the built in micro-usb connector on the phone and you can then open the phone view and edit its contents like a pen drive.
Hope this solution has been helpful?
Want to transfer photos from
Almost all phone right now can be installed automatically the USB driver that they need to work with a computer, so just connect your phone to your computer via USB and wait until its detected and after that you can already transfer the data from phone to computer.
I will be traveling to
Hi.
If you travel abroad the CDMA phone (your Katana in this case) will start automatically functioning in Roaming and using the resident networks in any country having CDMA network.
In Singapore StarHub provides CDMA mobile service.
To know prices and tariffs check the phone provider website. To give you an example of how roaming works with CDMA phones,
here Credo website. To know details, check your mobile provider website.
Remember to take with you a spare GSM mobile, althought Singapore has CDMA network, there is only one single provider using CDMA in the country.
How do I set phone to vibrate
To turn on the vibration of the phone,
First you go to the settings,
Select the profile,
Select personalize,
Go to the ring option,
Select the Vibrate and ring option.
Then you activate the profile.
Take care
How do I do 3-way calls?
All you do is put that person you have on the phone with you on hold, and then dial the next number and hit the green call button, then there should be an option to conference the two together.
Alarms
press ok..tools..alarm..select the alarm u setup..here is where u can turn on /off by toggle with the left / right softkey (dismiss)...alarm is off
The phone will shut off on it's own
Hi, its is possible the battery is bad and also make sure you have not over loaded the phone more than its capacity i.e applications and other downloaded things.
cheers
What is a Lock Code?
Use the last 4 digits of your phone number, if that doesn't work use 0000 depending on the model you have it could lock you out if you enter the wrong code 3 times. As your final attempt you have a choice to either use 1111 or remember the code the code you set on the device.
