20 Most Recent
Samsung Rant Cell Phone Questions & Answers
Picture assigned to all calls instead of one
this is what happen when you click assign i think you clicked assign the all contacts try click assign and click make sure you don't click assign to all contacts make sure you click the name of the person you want it to be assigned to.
vote me
Sometimes my text messages are coming in very
This is an issue, no matter what the company. Yes, they are trained to look at you that way. Till you tell them you will be changing companies....
I would dare to say that not knowing your location, it could be interference of building or other high line electrical, lack of towers, etc. Even going into certain shopping areas create delays on information. It happens here very often, and our whole community knows it. WHY does it always work when you are in church, tho!
I have a samsung rant and the charger port that is
there are 2 possible reasons for the problem u mentioned..
- either ur phone charger port or its internal connection is defected
- or ur charger circuit or wire orits pin is the problem
you can find it by connecting ur phone with system using usb data cable..if it charges then ur charger kit is to replaced..else u must service ur phone
WHAT IS LCD?
LCD is the own screen of every phone .... tv or pc/laptop.
#NZ
Moto atrix touch screen is not working is this
Unlock codes come from the network provider - usually takes around a week after you call up and request it.
I'd avoid other services like shops or websites that offer the service as we've had a phone bricked in the past when a shop did it.
Regards the screen - that can't be a common or easy to fix problem so you need to take it to the shop.
White screen on my samsung rant
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
My samsung rant keeps saying
It is a quick with the charger. Turn the phone off then try charging it. If that doesn't work, change the battery, and with the phone off, charge it.
How do i upload pictures from my samsung rant phone to my pc
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.Hi,I'm Ben and -- hopefully -- I can provide some meaningful assistance.Rather than providing you with a written procedure, I think that you'll find the following video tutorial of more value:
