20 Most Recent
Samsung Saga Cell Phone Questions & Answers
My phone dropped in water
Hi.I may be able to help you!If you place your Mobile Phone battery and the remaining pieces of the phone and wrap them in a towel, and place them into a high temperature area. Maybe outside for a short time in the sun so the heat can extract most of the water.Hope this helps.
I need unlock network pin for SAMSUNG SCH-i770, it
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...The procedure for flashing your mobile is in the link belowhttp://hubpages.com/hub/How-to-Flash-your-cell-phoneIt has an video explanation.If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who has stolen the mobile from using it with another provider...They will have a security check done with your date of birth etc..to verify whether you are the owner of the phone..After that they will provide you the restriction code to unlock it and use it with another service provider..It is all free of cost do not pay anyone for this seeing some advertisement over internet . That is all fake ads.For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
I have one Sansung
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Hi, pls i need my
yes surely you can unlock your sim in the mobile, with the help of the codes you can unlock it, so get the unlock code for your mobile, through this site
www.superunlockcodes.com/samsung/rs12wp8 , it has the best instructions and simple methods for unlocking your samsung mobile from the network lock.........If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
Was deleting some txt msgs...
was deleting some txt msgs... it deleted all the whole series of text
msgs...didn\'t want that. so they should have been in the delete
folder...they were not. i was a nervous wreck for i needed them!!! Did a
search and found them by searching in messages only. now they are all
itemized. resent a few but now they show from me... so then i marked
them unread and now it shows there are unread message but no messages to
be found....i have had this phone for years and haven\'t had this
problem before. Now I\'m afraid to take the battery out for I may lose
the rest of the text msg in the search folder that houses the txt
msgs. how is this fixed? I want to achieve all the txt msgs in the
serach to be moved back to the txt msg inbox as they originally
were..all in one series. Also in the search it seems to have all txts
msgs that i was searching for...meaning even the sent ones recently sent
are there
Usually memories are such that when things are deleted from them they keep a shadow copy of the item which is deleted from the memory. Most mobile devices once the the text message is deleted from the device the device doesnt keep a copy of the message. If you are lucky enough to get the messages itemized in a search and you can resend them to yourself then the best way to get them back will be to send them to yourself.
Although if the search shows them then there is a probability an attempt to archive the messages on these 3rd party synchronizing sites. You could try rseven.com it works wonderfully.
Hope this solution has been helpful?
Can you provide me with a network code for samsung
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
The phone keeps cutting it
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
