20 Most Recent
Samsung PN50A550 50 in. Plasma TV Questions & Answers
PN58C8000YFXZA purple
Make sure you don't have a speaker near the tv the magnit in the speaker can pull the gas leaving a purple colour
Samsung TV 4 red blinking lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
When I turn on my Samsung PN50A550 the screen has
hello, at this point the price of the bill is uncertian but it seems to be a one of your internal boards is going bad either way it needs service if your able to get a picture and sound after a few minutes then your set is repairable but the price depends on the actual board thats affected, these sets have power board, video audio boards and other boards that control the video signal going into the display, it would help to have a service manual and look at the individual boards to indentify the trouble, on thing you can do is search the auction site for a same type and model tv with a broken screen usually run like 150 or even less and have a tech exchange the part or parts.. hope this helps
I got a tv donated to our church for bible study
If you have changed these boards you need to first check your Va and Vs voltages, you should see a white paper listing the proper voltages, if you have a way of checking there are TP where you should put meter and get the proper voltage and also pots that you turn to change voltage. Make sure these are there first before continuing Bill.
Lost sound on tv suddenly
Just check whether the mute button on remote is jammed. Then if that is ok, check whether you can listen to the sound on a Head Phone connected to the TV. Even if it works, the TV needs attention by a qualified service technician.
When I turn on my
Hi tlc19732001,
Power on the unit in the dark room then shine with the flashlight directly in
the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing
24vdc coming from this board feeding the inverter board. This is caused by
faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even
the 24vdc is good from the power supply, if the fuse, driver transistor, driver
transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
When cut tv on it
usually this is a fault with the power supply in the tv. the capacators only hold enough charge to turn on the tv but not maintain the proper current to keep it on. contact a repair technition or the manufacturer.
