20 Most Recent Olympus Mju Tough 6000 Digital Camera Questions & Answers
How do i copy pictures
Use the "Backup" command. See page 40 of the manual: Owners Manual User Guide for Olympus Mju Tough 6000 Digital Camera
11/20/2014 4:43:17 AM • Olympus Mju... • Answered on Nov 20, 2014
2answers
Push on button camera doesnt budge but playback is okay!
I have this problem. PLease send me solution. THX
3/28/2011 6:31:56 PM • Olympus Mju... • Answered on Mar 28, 2011
Olympus 'u tough 600' camera frozen
Suggest you take it to the Olympus service centre. Mine had water going in as well, but because it was under warranty, they managed to help me fix the unit.
Gerald
5/7/2010 9:05:24 AM • Olympus Mju... • Answered on May 07, 2010
How do i set the self timer
Press the self-timer button. It's the bottom button of the cross-shaped pattern on the back of the camera, marked with a one-handed clock. Use the +/- and self-timer buttons (top and bottom) to select the setting option. After the shutter button is pressed all the way down, the picture is taken after a time delay.
"Using the self-timer" is on page 22 in my copy of the manual.
3/25/2010 6:47:26 PM • Olympus Mju... • Answered on Mar 25, 2010
My camera takes a long time to focus and take a
Hi there can you please select the camera mode in AUTO focus and click the photo. If its in macro photography mode that time it will take time for focusing. If you face the same problem in auto mode also then the lens guide pin is damaged & thats why you face that problem. Thanks & waiting for your feed back.
3/23/2010 11:38:32 AM • Olympus Mju... • Answered on Mar 23, 2010
When I push the on button an image with a sound
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/20/2009 10:57:29 PM • Olympus Mju... • Answered on Dec 20, 2009
2answers
I just finished copying the memory card to my usb
There is a small switch on the left side of the memory card. Slide it up and the card will work. On my SD card it is yellow.
And then insert it back and check Let me know if this will help
11/29/2009 7:08:57 AM • Olympus Mju... • Answered on Nov 29, 2009
Taking "night" photos ("flash") - takes too long
Any 'night' shot will take longer... and if you have 'Noise Reduction' turned on, it doubles the amount of time it takes to process the picture. Its probably best to leave that setting enabled, also.
6/2/2009 12:08:09 PM • Olympus Mju... • Answered on Jun 02, 2009
Write Protect Error Message
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
However if you need to save these images first: As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
5/19/2009 4:25:14 PM • Olympus Mju... • Answered on May 19, 2009
Olympus mju 1 Pressure plate
You mean the pressure plate that presses the film flat? Parts suppliers https://www.google.com/search?q=olympus+mju+1+pressure+plate+replacement ..
3/19/2023 6:32:19 PM • Olympus Mju... • Answered on Mar 19, 2023
Connecting error
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/9/2013 2:31:43 PM • Olympus Mju... • Answered on Aug 09, 2013
2answers
Hi! can i use xD 2GB TYPE M+ CARD WITH OLYMPUS STYLUS 300 DIGITAL?
  • The Olympus Stylus 300 camera works with xD-Picture cards, including the 2GB Type M+ card. But it's important to make sure the camera can use that particular type and size of xD card by checking the camera's specifications and list of compatible devices.
4/3/2024 5:36:15 AM • Olympus Cameras • Answered on Apr 03, 2024
My Olympus fe320 has a blurry screen & takes blurry pics. Is there a fix / solution to this?
Could be a steamed up lense or just dirt from storage. It is over 10 years old so possibly past its best by date but take it to a photographic shop and ask them for an estimate.
9/20/2023 4:02:06 PM • Olympus Cameras • Answered on Sep 20, 2023
Olympus Tough T-100 12.0MP Digital Camera. How can I fix it? It is still not working.
Question edited for clarity. It sounds like your battery has failed or have you tried two of them? Is there a date on the battery? They don't last forever. Check the charger for output using a digital multimeter. Also try cleaning the battery contacts on the battery and in the camera. https://www.google.com/search?q=olympus+t100+battery Powered with a LI-80B Lithium-ion battery (recharged via the included AC adapter) you can enjoy shooting the T-100 for about 190 photos per full battery charge. ..
9/9/2023 7:40:29 PM • Olympus Cameras • Answered on Sep 09, 2023
Olympus Mju Tough 6000 Digital Camera Logo
18 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Mju Olympus
  • Mju Olympus
Most Popular Question
camera takes long time focus
  • Cameras
