20 Most Recent Olympus STYLUS-550WP Waterproof Digital Camera Questions & Answers
2answers
The camera says remove usb
Have you found a solution already? I have the same problem!
9/14/2012 6:05:37 PM • Olympus... • Answered on Sep 14, 2012
0answers
Were can I find a manual for my camera, I've
You can download a free PDF manual and/or order a printed manual from the manufacturer at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1445
6/20/2011 11:04:48 PM • Olympus... • Answered on Jun 20, 2011
My Olympus Stylus 550wp camera
Have you found a solution? I have the same problem!
6/2/2011 3:31:30 AM • Olympus... • Answered on Jun 02, 2011
2answers
Cannot get an Olympus Stylus-550WP
you have a faulty capacitor it the circuit of your camera
It holds the needed voltage to operate correctly
The cost to repair it generally is more than the cost of a replacement camera sorry to say
3/28/2011 2:19:51 AM • Olympus... • Answered on Mar 28, 2011
Service Show rooms in Hyderabad
Describe in detail th expection to make available assistance.
2/10/2011 2:51:04 PM • Olympus... • Answered on Feb 10, 2011
I have a 550 WP
Unfortunately, these "waterproof" cameras don't always work as advertised. If the camera is still under warranty, I'd start there. It may be too late for this, but an old trick to dry out electronics is to put it in a bag of white rice for a few days to absorb moisture. It's a long shot, but I revived a wet cell phone once this way.
2/3/2011 8:34:00 PM • Olympus... • Answered on Feb 03, 2011
Cant charge camera
p/l check your cam battry & call for you olympus serivce center
12/25/2010 1:16:23 PM • Olympus... • Answered on Dec 25, 2010
My screen is cracked. Do
The crack screen will find at the nearest Olympus Customer Support or you get get online support by clicking here
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Here you can find the parts price, service locations and online help from Olympus.
It is recommended that you may repair your camera from the service center because camera needs more technical expertise than ipod.
Good Luck
12/18/2010 7:16:31 AM • Olympus... • Answered on Dec 18, 2010
"remove usb cable" but no cable is in there?
Just try to restart your camera then remove the battery and the memory card for 2 mins. then put them back in
after that it will be fixed. ^_^
6/11/2010 12:32:43 AM • Olympus... • Answered on Jun 11, 2010
My screen is white and won't turn on i think the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dry camera and battery completely. Here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
5/24/2010 8:56:26 PM • Olympus... • Answered on May 24, 2010
Problems with Olympus STYLUS-550WP 10 Megapixel
1 week old?...take it back.
1/23/2010 9:38:17 PM • Olympus... • Answered on Jan 23, 2010
0answers
Curved lines on playback screen and prints. Monitor screen is fine. Is it repairable?
Get a quote some cameras cost more to repair then to replace.
7/10/2015 1:39:57 AM • Olympus Stylus... • Answered on Jul 10, 2015
Olympus stylus 1 just froze with lens extended. I took battery and card out for 2 hrs. and still no power.
Try this, set the dial to P, then open the battery door and then press the Menu button and OK button together for about 5 seconds. If you see something in the screen like Olympus? Then press the Menu and OK button together again for another 5 seconds, this is a hard reset and hope it fixes your problem?
12/14/2014 1:29:18 AM • Olympus Stylus... • Answered on Dec 14, 2014
Why is my Camera stuck on and beeping, screen blank
Lens is out of correct possition.
7/31/2014 7:22:48 PM • Olympus Stylus... • Answered on Jul 31, 2014
Why camera says one moment and does not seem to want to recognize computer
Most brands of cameras deliver a CD with the camera, containing software, needed to backup, transfer and work with the pictures you shot, to a computer. Most of the time there is software is for both, Windows and MAC. Before you connect the camera to any computer, you should install the software. The disk also has the drivers for the old operating systems. If you lost the CD, or just don't know where it is right now, you can go to the site of your camera brand and try to download the software you need. For that look under support. If your camera is old, and the brand does not exist anymore, try a freeware picture transfer / editing software pack. Like Gimp or Adobe Photoshop elements. Just connecting a camera to a computer causes two things. The camera shuts down, and the computer won't recognise the camera. So nothing works. If you can't get software form your brand, you always can install other generic software like Ulead, Pixir, BeFunkey, Gimp, Photoshop express. Or if that is not possible you could install an external memory card reader and download the pictures via de memory card reader.
6/21/2014 4:08:28 PM • Olympus Stylus... • Answered on Jun 21, 2014
Pictures will not download into pc
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
4/20/2014 2:54:40 PM • Olympus Stylus... • Answered on Apr 20, 2014
Olympus STYLUS-550WP Waterproof Digital Camera Logo
17 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
cannot get olympus stylus 550wp
  • Cameras
