20 Most Recent Nikon COOLPIX L100 Digital Camera Questions & Answers
2answers
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos. All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level. A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash, Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
5/12/2022 2:02:22 AM • Nikon COOLPIX... • Answered on May 12, 2022
I have a nikon coolpx L100 yes a sd card in it but it puts pic i take on the internal storg &tells me it is full. i have bought 2 new sd cards but it still does it how can i get it to read the card?
Is this information not contained in the manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
2/21/2017 8:43:58 PM • Nikon COOLPIX... • Answered on Feb 21, 2017
When I take a picture with my Nikon Coolpix L100 there are shadows on the right side of the picture any suggestions.
look at the lens and ensure there is no dirt - fingerprint etc on the lens. Otherwise, it is time to visit your local camera store.
5/17/2016 2:16:13 PM • Nikon COOLPIX... • Answered on May 17, 2016
Is there a common problem why the L100 just stopped turning on ?
the mother board comes faulty, check the battery contact for corrosion, clean it.
2/1/2016 10:56:07 AM • Nikon COOLPIX... • Answered on Feb 01, 2016
Nikon Coolpix L100 camera will not turn on
You must have dropped the camera or hit it . If it is the case you probably bent the casiing the will prevent the camera to function.
1/26/2016 7:37:52 AM • Nikon COOLPIX... • Answered on Jan 26, 2016
When i take a picture a red light flashes olong and i want to take it off because it makes the pictures look weird plz help me
Go to this site and download a free copy of your user manual. It should tell you how to operate your camera: https://support.nikonusa.com/app/answers/detail/a_id/16311/~/users-manual---coolpix-l100
5/12/2015 5:02:42 AM • Nikon COOLPIX... • Answered on May 12, 2015
I just took a ton of still pictures for a home staging/real estate portfolio, and when I downloaded them on my computer 90 percent of them are fuzzy (not blurry, just not sharp). I just realized I too
You will need a photo editing softwares! There are loads to choose from it depends on your budget and how much you want to spend! Most offer free trials, so take your pick and get testing!
11/14/2014 8:02:55 PM • Nikon COOLPIX... • Answered on Nov 14, 2014
Why is my camera only seeing black?
Check the menu....ensure B&W option is not selected..
10/15/2014 7:57:27 AM • Nikon COOLPIX... • Answered on Oct 15, 2014
Lost my installation disc
Nikon COOLPIX L100 Digital Camera, go to Nikon.com, they should be able to get another disk to you good luck.
5/25/2014 8:32:13 PM • Nikon COOLPIX... • Answered on May 25, 2014
0answers
Hi I am having Nikon L100 since 2009. Problem: Nikon Coolpix L100 battery holder has some groves which are broken( due to wear and tear) which helps holding up the battery lid. Is there any way to fix
I'm affraid, only a new housing (or at least the part where the battery holder sits) should solve this problem. There are 4 batteries pushing against the door so when the groves are broken out of the housing it will be difficult to glue anything in place. If it should be my camera, I should try to work with some glass fiber and a two-component adhesive. But not every material will accept glue.If you never have worked with two-component adhesive don't start at all.
11/6/2013 12:50:11 PM • Nikon COOLPIX... • Answered on Nov 06, 2013
The zoom control button, is like its stuck only
and I also
10/13/2013 10:13:21 PM • Nikon COOLPIX... • Answered on Oct 13, 2013
0answers
Usb driver
Be the first to answer 10/13/2013 9:17:31 PM • Nikon COOLPIX... • Posted on Oct 13, 2013Be the first to answer
Nikon COOLPIX L100 Digital Camera Logo
196 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
black white mode in nikon coolpix l100
  • Cameras
