20 Most Recent Toshiba Satellite® A135-S2266 PC Notebook Questions & Answers
did you try driver guide I have also had great luck with Driver Detective both places work well
Toshiba... | Answered on Jul 14, 2009
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Toshiba... | Answered on Jul 12, 2009
Your harddrive is locked and is asking for a password call toshiba and they'll be able to help you.
Toshiba... | Answered on Jun 17, 2009
One thing is for sure... if you didnt some else did.
Not to worry.. try this:
Boot up the notebook and immediately hit the F8 key until you see the menu option to boot in Safe Mode. Choose Safe Mode from the menu.
Once the system finishes You will be given a choice of Yes to enter Safe Mode, and No to enter System Restore Mode Choose YES
Hopefully there will be no password on the Adminstrator account and you will be able to log on as administrator.
Once logged in, go to Control Panel, User Accounts and create a new user account with administrator privlidges.
After creating this account you will be able to boot the normal way and log on to the new account.
Toshiba... | Answered on Jun 15, 2009
It might be worth having a quick look here first:
http://www.laptop-repair.info/toshiba_bios_password.html
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Keydisk - http://www.cgsecurity.org/keydisk.exe
** I have downloaded this file myself from the link above and scanned it with microsoft one care, it came up clean **
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Toshiba... | Answered on May 13, 2009
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
Toshiba... | Answered on Apr 29, 2019
Take another video and don't drop your gear. The mishap obviously ruined the original.
Toshiba... | Answered on Apr 02, 2019
Toshiba Satellite® A135-S2266  PC Notebook Logo
9 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
computer wants password isnt one
  • Computers & Internet
