20 Most Recent
Acer Aspire One AOA110-1113 Netbook Questions & Answers
I've got a serious problem
you may have corrupted your disk drive. If this is the case, you will need to take your computer to a repair center where the can remove the disk to correct before a reinstall.
Slow buffer/shutter during music play and video play
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid such type of problems, The one well known and reliable program is Reginout to manage everything on your PC & will secure your music from lagging or shuttering. Thanks
Acer aswz keys
Did you spill any liquid on the keyboard? Try to dry it.
Restore
I actually have one of these, I just went and got Fedora 10 (Fedora version of Red Hat Linux vs. the pre-installed Linpus version of Red Hat Linux) and installed it instead. Anyways, there should be a way to take the cd, load it onto another computer, and have it put itself on an empty 2GB (or bigger) USB thumb drive if you can't get a cd loaded onto it. I did this several times before I went to Fedora 10, and the wireless works in Fedora 10.
Error message on power on'
Press F2 or the Delete key to enter the bios. There's usually an option to load the default settings and then save and exit. Check the Exit menu, it might be there.
SM Bus Controller - Acer
Download a free program called driver max from
www.drivermax.com it is capable of scanning your computer for unknown hardware and directing you to the right driver download and installing it for you. Can also find updates for all other drivers and will let you download 2 per day for free. ........cheers from Scott
Describe your intel (r) atom (TM) cpu N270 Acer
The BIOS cannot detect anything attached where the boot source should be. It almost always means that the hard disk has died - you will have to replace it. But before doing that check in the BIOS that the boot order is the correct one: 1 - hard disk; 2 - removable device; 3 - disabled.
How do I factory reset my Acer N270?
Hello
1. Restore your unit back to factory default via boot up on the ACER screen, hold down ALT and tap F10.
2. Select "Restore system to factory default".
3. Enter your Empowering Technology password and away you go.
If that doesn't work, your unit was shipped with recovery cd's
Hope this helps
Aspire one model za3 user guide
Hello, your laptop is known as the Acer Aspire One 110, here is a direct link to the laptop from Acer. at the bottom of the screen you see a drop down menu for Technical Documentation, though I think Acer only have them in German? :-s
A default profile could not
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
My acer atom is showing
They don't like two systems on the same computer unless it is set up so.
re install Win7 on drive "C".
You can then restore your backups as Windows Backup/Restore is compatible with older Windows Systems
