20 Most Recent
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Questions & Answers
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
- Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
- Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
- Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Brother DCP vs MFC
i was came into this as well when looking to buy a printer. after doing some research, from what i can tell the MFC printer/scanners have fax capabilites where the DCP do not. there might be a few other functions the MFC's have the DCP's don't, but Fax is the big seller
DCP stands for Digital Copier/Printer
MFC stands for Multi-Function Copier/printer
here's a copmarison of two dcp's against comparable mfc's on newegg with full spec list
http://tinyurl.com/yaugt6t
Can you show me all the list of the drivers for brother printer
They differ depending upon where you are geographically, but if by any chance you are in the UK try these: http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_top.html?reg=eu&c=gb&lang=en&prod=dcp135c_eu_asOtherwise you can get all drivers for all regions from here: http://solutions.brother.com/Hope this helps.
