20 Most Recent
Dell 2130cn Laser Printer Questions & Answers
I have a constant 'paper jam' message on DELL 2130cn.
Perfect printing from my 2130CN but increasingly constant paper jams. Various Codes, 077-102, 077-901, 071-100 and 071-700. Checked the roller in the tray and found it was not free running - quite difficult to turn. I felt this was wrong but was unable to free it up. Clearly designed not to be free running by some system inside the roller itself. Had discussions with Dell where they advised a new roller kit was required, but they didn't have one. Maybe later!
I looked more carefully at the roller and decided to make it free running as I felt it should be. Two small lugs on the white plastic support at one end locate with the system inside the roller preventing it from rotating without considerable force being applied. I ground off the two locating pins allowing free rotation and re-installed. Printer works now works perfectly. Asked Dell what is inside the roller but they respond that they want to talk on the phone - but they don't. I suspect that whatever is inside the roller expands and slowly jams over a period of time requiring it to be replaced on a regular basis! With no information from Dell I suspect a simple SCAM to make money!
[email protected]
I have replace the fuser on my dell printer
If the NVRAM reset doesn't work contact dell support as they will likely replace the printer if it is still under warranty.The recommended powersource for the printer is to be plugged in to an independent wall outlet. Thereasoning is that laser printers need a large surge of power to print and surgesuppressors are designed to not let any surges through. While the printer maywork for a while, over the long term it can damage the inner workings of theprinter. Plus, the way the High Voltage and Low Voltage power supplies arebuilt, together they work as a built in surge protector.
What does the User Intervention on a Dell 2130CN printer mean?
Either the print was stopped from printing. check print queue.
Or the printer was turned off during print
Open the inspection doors
pull out ink cartridge, put back in
Check for paper stuck in printer
make sure you print Queue is empty
remove usb and turn off pc
restart and plug usb back
How to fix error 616-302
Automatic Solution for Novice PC Users (no manual option selections are required):
- Download the Dell 2130cn Printer Repair Tool
- Install the application after download completes
- Click the "Scan" button that appears on the first interface
- Click the "Fix Errors" icon that will appear once the automatic scan has finished
- Restart your system as usual
1 tcp/ip printer works on 3 out of 5 computers XP and Win8
What version of driver are you using? I've found that sometimes an older driver will work for the new computers. I'm noticing that Dell has their Open Manage Print Software that covers all the drivers that you would need. The thing is, there are also multiple versions (A08, A09) of that as well. I would try them
