20 Most Recent Motorola Talkabout T6310 (14 Channels) 2-Way Radio Questions & Answers
Here is a link to the user guide for the T6300 series. http://www.giantintl.com/ContentManage-new/manuals/Moto/T6300_User_Manual_E.pdf
The instructions for tuning the FM radio feature are on pages 22-23. You can have the radio scan for available stations, or you can do a manual search .01khz at a time. Once you have found a station, you can save the location.
Best regards.
Motorola... | Answered on Mar 07, 2013
We have discussed your dilemma. Check your audio jack hole to be certain nothing is still in the hole. Check to see you have the VOX setting turned to a normal or off setting. Typically the radio will shut off the front speaker when an audio device is plugged into the jack. If the radio senses the device, or a small piece of the plug is stuck in the jack, or the jack is damaged, it will shut off the front speaker.
Since you can hear when using the headphone, it is apparent you have the radios programmed to the same frequency and code settings. This leads us to believe it is not a programming issue, short of the VOX feature, or mic gain. You might double check these settings.
Here is a link to the manual: http://www.usersmanualguide.com/motorola/2-way_radio/t6310
Motorola... | Answered on Sep 09, 2009
Hi Folks, two seperate checks to do - to check vox on autocom and transmit on motorola. With the T5622 unconnected to anything, does the push transmit button work - e.g. does it make the beep noise at the end of transmission?
Does your autocom work with any other sound sources - i.e. mp3 player so you can hear music. Does this mute when you speak ? (it should if vox is working). Note that in this setup vox is provided by autocom - NOT BY THE T5622. The instructions you mention are for the motorola vox kit.
Wire the two together and you should get the motorola beeping through your autocom at the end of transmit - that's what my kit 200 does with my T5622.
Motorola... | Answered on Jun 13, 2008
check if the mic is not dirty, there is nothing that you can do to fix this problem.
Motorola... | Answered on May 07, 2007
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on Nov 03, 2019
please, try long press P2 button, to unlock your radio,
and re-try,
Thank you,
With Regards,
jack
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
Motorola Radio... | Answered on Oct 04, 2019
Entering Front Panel Feature and Button
Configuration Mode
If your radio is turned ON, turn it OFF. Press and hold the side
programmable button 1, and turn your radio ON. A tone is
heard, indicating that your radio is in Feature and Button
Configuration Mode. The indicator illuminates and the
"BCKLIGHT" is displayed on the radio LCD screen.
Whenever the radio is turn on, it initiates a self-test routine which checks the RAM, EEPROM
hardware and EEPROM checksum. If Self Test passes, the green LED flashes once and a Self-Test
Pass Tone is generated. If unsuccessful, the red LED flashes rapidly and a Self-Test Fail Tone is
heard
You may need the programing software to do the reset the manual does not give you any info on resetting the radio
Motorola Radio... | Answered on Oct 03, 2019
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Motorola Radio... | Answered on Sep 26, 2019
Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
Motorola Radio... | Answered on Sep 20, 2019
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Motorola Radio... | Answered on Aug 31, 2019
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. radiodude365@yahoo.com
Motorola Radio... | Answered on Jun 16, 2019
Motorola Talkabout T6310 (14 Channels) 2-Way Radio Logo
Popular Tags
5 questions posted
Top Motorola Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
two motorola t6310 two radios fm radio
  • Radio Communications
