20 Most Recent
Kenwood KM300 Chef Stand Mixer Questions & Answers
Can't remove steel bowl from
I am having this problem - I know it's a twist and twist off thing of course as I've used it many times. But now twisting it off is not working and I need to wash it!!! Can't believe this of all things has gone wrong, never mind anything electronic!
Kenwood KM300. How to fit new mains cable ?
Having done it the hard way (!) it is dead easy. All you need is a small screwdriver or similar, approx 2mm by 1mm in cross section. Looking from outside the mixer, where the power lead enters the main body, between the rectangular lead casing and the socket it enters, there is a small rectangular cutout (top right). Push your screwdriver in around 15mm, and then withdraw the lead housing with it - the screwdriver pushes the latch aside, hence you need to remove both as one! With luck, and a wiggle or two, that should be it.
Compatibility of mincer attachment
1) remove the front power outlet of the mixer head. 2) look for a notch in either the top edge or the bottom edge of the casting. (hole)3) Guide Pin on 9xx accessories is at the top of the connecting shaft. 4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
Service advise for kenwood a700d
The planetary gear housing is filled with grease. Seeing oil come out would indicate that grease has started to or has completely broken down. Take the planetary apart (One nut and a clip), clean out the old grease and liberally repack with a food grade grease something like PTFE Super Lube .
