20 Most Recent Honeywell HE360A1027 Whole House Humidifier Humidifier Questions & Answers
I recently had a solinoid
The replacement solenoid may have been defective.
10/30/2020 12:50:46 AM • Honeywell... • Answered on Oct 30, 2020
2answers
Honeywell 360a humidifier
yes water should turn off solinoid is bad
5/28/2018 7:22:04 PM • Honeywell... • Answered on May 28, 2018
0answers
Need to trouble shoot circulator pump. Aquastat
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
4/9/2016 5:50:07 PM • Honeywell... • Answered on Apr 09, 2016
Mildew
If you are keeping your humidifier set to 76, this is far too high. A humidifier setting of 40 to 50 percent is about right. Depending on your window insulation, you may have to reduce the setting in very cold weather if you start getting condensation on or around the windows.
Hope this helps.
Anthony Newman
8/25/2014 3:26:13 PM • Honeywell... • Answered on Aug 25, 2014
0answers
White dust in the house
Use mini RO system or good filter to feed humidifier with water that contains less minerals.
12/1/2013 5:47:38 PM • Honeywell... • Answered on Dec 01, 2013
Water runs continuosly on my Honeywell Envirocaire Elite system, no matter what setting I have the automatic humidity control set at, should I try replacing the Kip valve #3703?
Try to disconnect the main power to the unit and if the water valve is still open and water is running, you have a bad valve (the valve stuck open). Tap on the valve body it may help on sticking it, if not replace it.
12/1/2013 5:33:35 PM • Honeywell... • Answered on Dec 01, 2013
Fan and water run continuously on he360
I'm not sure what wiring option did you use, but looks like you did not include pressure or sail switches... When the furnace blower/fan is off it should open the 24volt circuit and close the water valve (normally close) and turn off the fan. If you can post more wiring details maybe pictures or hand sketch I'm sure problem can be fixed in the few minutes.
12/1/2013 5:24:38 PM • Honeywell... • Answered on Dec 01, 2013
How to manually activate a humidifier solenoid
If humidifier is running but water valve is not clicking open, check the wire connections. If connection is OK, than unplug the humidifier from 120V outlet, disconnect water valve wires and with multimeter check resistivity on the valve coil. If the coil is burned out/open/no resistance, the coil needs to be replaced.
12/1/2013 5:08:32 PM • Honeywell... • Answered on Dec 01, 2013
Can honeywell 360 humidifier be installed on return plenum
Yes. Make sure to connect to HOT water line for better performance.
12/1/2013 4:53:35 PM • Honeywell... • Answered on Dec 01, 2013
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
12/1/2013 4:58:42 AM • Honeywell... • Answered on Dec 01, 2013
0answers
Need essickair humidifier manual
Follow the provided web link. Select from the appropriate category of humidifiers by Essickair, then click on the "More Info" link after which you should choose the specific model humidifier that you own. After doing so you will find a link to the lower right(under "Resources") saying "Owners Manual."Clicking that Owners Manual link will allow you to open and/or save your humidifiers manual.
10/18/2013 3:44:49 PM • Honeywell... • Answered on Oct 18, 2013
Honeywell humidifier short cycles
It's not uncommon for duct work in an older home to Bang as the furnace cycles due to age. The humidifier banging while turning on and of is mostlikely the solenoid valve; if the solenoid is bad it is actually to your benefit to replace the entire humidifier as the solenoids are very expensive, 50%+ of a new humidifier. Plus you get the 5 year parts warranty on the new unit instead of just one year on the solenoid. If you don't want to replace the entire unit you can replace the Humidistat, and that should fix the on/off cycling, however a new humidistat is included with a new unit, which again is more cost effective. They are easy enough to replace as a do it yourselfer, especially when replacing an existing unit. I hope this helps you.
12/29/2012 6:26:42 PM • Honeywell... • Answered on Dec 29, 2012
3answers
Humidity not going up
I have a similar problem with mine too. I am interested to see if anyone can diagnose this problem
2/7/2012 12:09:35 AM • Honeywell... • Answered on Feb 07, 2012
I have a HE265Ahumidifier it keep burning out transformer whats wrong
Hello, usually the transformer will burn up when the amp rating of the transformer is being exceded or if there is a short in the low voltage wiring
12/9/2011 7:51:45 PM • Honeywell... • Answered on Dec 09, 2011
The solenoid valve is not
Hello, if you are getting 24 volts to the solenoid valve and it is not working replace it. However, if you are not getting 24 volts check the humidistat, transformer, and wiring.
3/23/2011 3:30:58 PM • Honeywell... • Answered on Mar 23, 2011
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
92 questions posted
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Humidifiers
Most Popular Question
installed honeywell 360a flow thru
  • Humidifiers
