20 Most Recent GE Advantium SCA2001BSS Microwave Oven Questions & Answers
Change spark
Check diode and capacitor. Instructions should be found inside the unit.
11/28/2017 11:56:05 PM • GE Advantium... • Answered on Nov 28, 2017
Repair
please see this details and fix it. God bless you1. No power to outlet (overload or fault in microwave or other appliance). 2. Blown main fuse - likely due to other problems. 3. Open thermal protector or thermal fuse. 4. Defective controller or its power supply. 5. Clock needs to be set before other functions will operate (some models)
7/9/2013 12:30:53 PM • GE Advantium... • Answered on Jul 09, 2013
I have a GE Advantium
They are the same the SCA2001Bss is a newer production model.
Order the Magnetron from Bi Coastal Appliance Parts @ 1-800-673-1262
Part # WB27X10327
8/18/2011 3:01:45 PM • GE Advantium... • Answered on Aug 18, 2011
0answers
2answers
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
5/5/2011 5:21:54 PM • GE Advantium... • Answered on May 05, 2011
2answers
Microwave lights and fans
If the microwave sounds normal, but not heating, then the magnetron is bad and needs to be replaced. If it is making a humming noise, then the diode is bad. I recommend that if it is the magnetron, ou also replace the diode.
2/11/2011 12:48:51 AM • GE Advantium... • Answered on Feb 11, 2011
FUSE BLOWN PART WB27X10388
http://www.appliancedepot.com/parts/parts-used/fuse-microwave-ge-wb27x10388-jvm2070sk02-jvm1871sh02.html
That is a supplier for you.
It is a semi surge sand filled ceramic fuse and the rating will be stamped on the end cap.
Hope that helps.
1/3/2011 4:55:32 PM • GE Advantium... • Answered on Jan 03, 2011
0answers
Our advantium oven has just stopped working. the
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/15/2010 4:37:44 AM • GE Advantium... • Answered on Nov 15, 2010
After replacing the door latch,
The capacitor is bad and will need to be replaced,
Please make sure that you know what to do and how before attempting repairs on a microwave...they can be deadly...
Here isa tip that will help you to figure out what is wrong with your MicrowaveOven....
heatman101
9/30/2010 1:25:21 PM • GE Advantium... • Answered on Sep 30, 2010
My wireless USB transceiver for
No the logitech mouse will not work with the microsoft receiver. The reason why is that they are on 2 different frequencies. If they were on the same frequency then you would be ok but they are not.
3/14/2010 7:02:51 PM • GE Advantium... • Answered on Mar 14, 2010
GE Advantium SCA2001BSS Microwave Oven Logo
51 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
microwave lights fans
  • Microwave Ovens
