20 Most Recent GE JE1640WA/GA Microwave Oven Questions & Answers
My GE JE1640 microwave has the following problem:
What do you mean you checked the door interlocks? did you remove them and take a resistance reading? Or do they look like they are there? I am sticking with the door switches as the problem..
10/29/2017 5:52:34 PM • GE JE1640WA/GA... • Answered on Oct 29, 2017
0answers
Vent fan
I would be sure the filters and ducts are not blocked.If you recently had a problem with your cooktop lights, that can affect the fan, too, but that can usually be economically repaired.
1/9/2013 3:06:03 AM • GE JE1640WA/GA... • Answered on Jan 09, 2013
Jmc8100ad microwave oven no fan, no heat, no turntable
This is most likely a bad door switch or mount (usually the bottom but occasionally the top) or a defective relay or connection on the circuit board, which can be repaired.
12/20/2011 2:13:18 AM • GE JE1640WA/GA... • Answered on Dec 20, 2011
When door is open unit turns on and turntable
I have the same problem, and have not been able to find a solution. Any one with a coluiton?
11/26/2011 5:12:38 AM • GE JE1640WA/GA... • Answered on Nov 26, 2011
What is the dimension for
For model JE1640WA001 , the spec sheet is located here.
In case you still don't have it, the owner's manual is here.
7/10/2011 2:33:50 AM • GE JE1640WA/GA... • Answered on Jul 10, 2011
5answers
How do I remove the
Interesting video of how to get into a GE:
Service manual of a late model GE
More here
themobilian_1947.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/19/2011 1:45:07 PM • GE JE1640WA/GA... • Answered on Mar 19, 2011
Our microwave looks and sounds to be operating
If it sounds normal and not heating, you may need to replace the magnetron. this is a very common problem and normally occurs from the overheating of food.
if the microwave is making a gumming noise, then the diode needs to be replace.
2/8/2011 11:01:44 AM • GE JE1640WA/GA... • Answered on Feb 08, 2011
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
2/5/2011 12:44:36 AM • GE JE1640WA/GA... • Answered on Feb 05, 2011
Is the GE JE1640WA microwave still available? If
Sorry to read about your problem, I hope this helps you out.
your present unit is 1.4 cu ft capacity.
so just google, 1.4 cu ft microwaves
Exterior Depth 17.25 in.
Exterior Height 12.63 in.
Exterior Width 21.88 in.this is the size of your unit
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
1/1/2011 5:38:16 PM • GE JE1640WA/GA... • Answered on Jan 01, 2011
Microwave works with the door open
The top door switch is almost certainly defective or loose. Most likely the latter, and possibly due to a loose or broken mount. Chances are that only the fan and light are on, but it's not wise to take chances with microwave energy, whuch can cause burns and fire. One way to possibly test this theory is to pull up gently on the door and see if it stops doing it. But that's not a foolproof test. A broken or loose mount can be caused by inadequate plastic or improper assembly techniques during manufacturing, by slamming the door, or other physical damage. Bad door switches are usually caused by opening the door while it's cooking instead of hitting the STOP KEY first. I have a helpful text file on door switches with safety tips that will help you. You can find it by searching on Yahoo.com (not Google) for microwave safety.txt Good luck and be safe!
12/1/2010 9:24:13 PM • GE JE1640WA/GA... • Answered on Dec 01, 2010
Door latch broke.
Part is available,
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JE1640WA01&productCategoryId=0123245&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=E2134524&pop=flush
Eric
11/21/2009 6:20:15 PM • GE JE1640WA/GA... • Answered on Nov 21, 2009
GE JE1640WA problem
Chances are you have a bad primary interlock (top door switch) or its mount is damaged or loose.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
(Your mini-manual may show that your primary interlock is the bottom switch, so go by it)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
6/8/2009 4:39:13 AM • GE JE1640WA/GA... • Answered on Jun 08, 2009
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
5/29/2008 7:07:59 PM • GE JE1640WA/GA... • Answered on May 29, 2008
GE JE1640WA/GA Microwave Oven Logo
Popular Tags
31 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
vent fan
  • Microwave Ovens
