20 Most Recent
Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote Questions & Answers
Does anyone have a clear picture of how the wiring is suppose to go for the TSI Model 25ii033CGL
There is nothing on the maker TSI or the model number as you have written it. There is a 'Twin Star' in the link with a similar but different model number. If TSI is Twin-Star International, can I ask that abbreviations are never used on Fixya. You could ask their customer Service.
There will be two wires for the blower, just positive and return.
The heater will have one common return and a wires from the switch for low, a wire for medium, and a pair of wires that goes to both for high (low and med on together).
If it has a remote, then you have electronic switches via relays.
The clicking may be a faulty relay.
https://www.google.com/search?q=TSI+Model+25ii033CGL
Sorry not to be more help, but it just isn't out there.
10/6/2023 11:22:03 PM •
Leisure...
Answered
on Oct 06, 2023
NEED AN ON OFF SWICH
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
7/31/2019 5:24:11 PM •
Leisure...
Answered
on Jul 31, 2019
Electric Fireplace Insert
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
7/23/2019 10:51:51 AM •
Leisure...
Answered
on Jul 23, 2019
Electric fireplace just blows out cold air
It would seem to me that the Thermal fuse has "Blown" this is an internal protection device that operate from heat... they often fail spontaneously, when this happens oftem all else works but no heat.
You will have to take it to a reputable repair shop/man and get a firm "Quote" for repair.
4/20/2018 6:52:32 AM •
Leisure...
Answered
on Apr 20, 2018
Noisy fan on electric fireplace
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
10/24/2017 12:00:08 AM •
Leisure...
Answered
on Oct 24, 2017
We purchased a home with an electric start/gas
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
10/19/2017 7:12:47 PM •
Leisure...
Answered
on Oct 19, 2017
