20 Most Recent Lasko 2506 16", 3 Speed, Oscillating Fan Questions & Answers
Won't turn on
Check thermal fuse in-line in the white wire going to the motor windings. 2A/115 degrees C.
7/3/2014 10:27:25 PM • Lasko 2506 16",... • Answered on Jul 03, 2014
0answers
The switch of my fan is broken. It needs
You have a problem indeed. If it were MY fan, I would unplug it first, then I would remove the switch and solder the loose ends of the wires together that I removed from the switch.
I would also carefully wind black electrical insulating tape around the connection so nobody would get a shock from it or short out to ground. Then I could use the fan, but will have to plug and unplug it from the power source. If you have power points just flip the wall switch.
Jim Hart
6/20/2010 4:01:40 AM • Lasko 2506 16",... • Answered on Jun 20, 2010
Fan blade does not immediately spin when turned on; loud
The motor bearings need machine (like sewing machine oil).
Try a quick spray of WD40 or Liquid Wrench, but use machine oil, soon.
Look for an "oil hole" on top of the motor; there may be two of them.
10/5/2009 2:22:32 PM • Lasko 2506 16",... • Answered on Oct 05, 2009
Blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
5/11/2009 3:14:49 PM • Lasko 2506 16",... • Answered on May 11, 2009
Lasko Fan model 4920. Can I get a replacement remote for it please?
Lasko Fan Remote Control Replacement
Amazon.com https://www.amazon.com > lasko-fan-remote-control-r... Master Replacement Remote Control for These Lasko Fans and Tower Fan and Heaters only (Models List #1) Universal Only for The Heater and Fan Part in The Right ... Missing: 4920 ‎' Show results with: 4920
Parts Store - GuardianTechnologies
GuardianTechnologies https://lasko.com > pages > parts-store Whether you want to replace a lost remote control, need a new set of box fan feet, or are ready to replace filters, the Lasko parts store is available for ... Missing: 4920 ‎' Show results with: 4920
Remote Controls For Lasko For Fans
Remotes Remade https://remotesremade.com > collections > remote-cont... New and Used Remote Controls For Lasko For Fans. We have 3 options for each fan. Official remotes, Alternatives and Universal. Prices from $29.
11/26/2023 10:19:49 PM • Lasko Dryers • Answered on Nov 26, 2023
2answers
My tower lasko fan turns off & on by itself. What can be the cause of this?
if it has a timer setting adjust or turn it off other than that have it checked for an electrical fault by an appliance repair shop
6/25/2023 5:36:30 PM • Lasko Dryers • Answered on Jun 25, 2023
2answers
Disassembling a cyclone by lasko for cleaning
There are screws hidden between the slats on the side of the fan that are not obvious. You will also need to pry the fan apart as it snaps together. On the back by the power cord is a round tab over it. There are some screws under it. They hold the motor to the back assembly. It took about 7 minutes for us to get it apart today because of the screws being hidden on the sides. After a cleaning it won't turn on now.
5/27/2023 4:32:57 AM • Lasko Dryers • Answered on May 27, 2023
Lasko Pedestal Fan. I need remote for it please. The part number is 02035045b.
Question edited for clarity and spelling. From Lasko direct. Remotes are $17. You need the FAN model off the label on the fan. https://lasko.encompass.com/modelbrowse/LAS/10/15 https://remotesremade.com/collections/remote-controls-for-lasko-for-fans ..
12/1/2022 12:06:13 AM • Lasko Dryers • Answered on Dec 01, 2022
Lasko pedestal fan will not turn off, can not adjust speeds or timer
switch failure
9/6/2022 12:59:23 AM • Lasko Dryers • Answered on Sep 06, 2022
Troubleshooting a Lasko 2511 36" Oscillating fan stopped working.
most likely it is covered under manufacturers warranty https://www.lasko.com/resources/warranties/ suggest checking with Lasko first as any attempt to repair it could void the warranty it still might have .
4/29/2022 5:55:43 AM • Lasko Dryers • Answered on Apr 29, 2022
Lasko fused plug replacement?
HOW WOULD WE KNOW IF LASKO SELLS TO CONSUMERS
9/3/2021 4:08:29 PM • Lasko Dryers • Answered on Sep 03, 2021
How to clean a Lasko Mod 4910 fan?
I blow mine out with an air compressor outdoors
6/2/2021 10:36:01 PM • Lasko Dryers • Answered on Jun 02, 2021
I have a Lasko 48" air tower fan Model T48301 that will turn on but will not rotate purchased in August 2017. Do I need to get a new one??
You do not need to purchase a replacement if you can repair the rotation mechanism.
12/5/2020 4:58:13 PM • Lasko Dryers • Answered on Dec 05, 2020
Lasko tower fan. What caused it to stop working?
First thing is verification of power at the outlet .
9/26/2020 3:39:58 PM • Lasko Dryers • Answered on Sep 26, 2020
2answers
Where can you buy a switch for a Lasko fan 3300
Possibly here;
https://www.ebay.com/p/16013024244?iid=162948677077
No guarantee it will fit. May require minor change to existing wiring.
4/30/2020 2:23:21 AM • Lasko Dryers • Answered on Apr 30, 2020
Need blades 20201 Lasko box fan
https://www.lasko.com/products/20-inch-box-fan-b20201/ https://store.laskoproducts.com/p-1005-20-box-fan-model-b20201.aspx
3/26/2020 5:08:24 PM • Lasko Dryers • Answered on Mar 26, 2020
This a the fourth Lasko tower fan that the oscillator stops functioning within the first couple of days- is there anything I can do short of retuning yet another one?
i don't know. please check to ensure the switch or control for oscillate is firmly selected for ""oscillate"". move the control a few times to test.
8/30/2019 7:10:13 AM • Lasko Dryers • Answered on Aug 30, 2019
Lasko 2506 16", 3 Speed, Oscillating Fan Logo
8 questions posted
Top Lasko Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lasko Dryers
  • Lasko Dryers
Most Popular Question
switch fan broken needs
  • Dryers
