20 Most Recent Lakewood HV-18 Floor / Box Fan Questions & Answers
How do I remove the blades to access the motor?
blade pulls off... grab hold w 2 hands, pulling n wiggling with just enough force til it breaks free. Good Luck
12/20/2017 2:35:09 PM • Lakewood HV-18... • Answered on Dec 20, 2017
3answers
Are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
9/20/2015 12:12:06 PM • Lakewood HV-18... • Answered on Sep 20, 2015
How can I clean a Lakewood fan, mine is so filthy
ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
11/16/2013 11:50:41 PM • Lakewood HV-18... • Answered on Nov 16, 2013
0answers
3answers
Patton 1887 fan blades wont turn
I've had an 1887 since the 90s -- great fan. I have to say that FixinFax (Solution 1 above) probably didn't try to take his unit apart. My blade has stopped rotating several times over the years and I always got it going again by myself. I'm no whiz, just your average amateur handyman. In fact I am fixing the motherbleeper right now because in a week where the heat is 100 degrees it chose to slow down and stop.
Eventually it sucks enough dust into the axle housing so you have to take the motor mechanism apart and clean it. It's not terribly complicated, but you have to note how the electrical and mechanical parts go back together before disassembling. It's a little tricky to get all the housing parts to line up level again, you may have to try a couple times till the blade rotates freely. Wipe out all the dust and gunk buildup. Lubricate the axle with oil, or I just spray with WD-40. Then reassemble.
The only thing I have had to replace is the on-off knob, since it's plastic and it split. Just get a universal knob from your local hardware store.
8/22/2012 10:10:25 PM • Lakewood HV-18... • Answered on Aug 22, 2012
Need a source for a blade for a Patton U2-1887 fan
Try McMaster Carr -- page 640, Fans and Fan Blades.
http://www.mcmaster.com/#ventilation-fans/=8qgdv5
9/8/2010 2:18:39 AM • Lakewood HV-18... • Answered on Sep 08, 2010
Fan shows that the power is on, but fan not
Dust is evil to all mechanisms!! Keeep UNPLUGGED..then Vacuum all accumulated lint in fan motor assembly, and soak with WD-40...I just did detailed dust cleaning with toothbrush....Fan now runs awesome!! Good Luck
9/6/2010 6:35:41 PM • Lakewood HV-18... • Answered on Sep 06, 2010
0answers
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
5/29/2009 1:56:41 AM • Lakewood HV-18... • Answered on May 29, 2009
Any idea where I could get a replacement motor for a Lakewood model HV-18 fan? The motor is fried, sparks coming out when I turn it on.
Take the motor out and take to a local motors repair and rewinds shop. Drop it on the counter and say "can I have one of these please". It is just a motor, form size, voltage and speed. https://www.google.com/search?q=Lakewood+model+HV-18+parts ..
2/14/2024 6:21:34 AM • Lakewood Dryers • Answered on Feb 14, 2024
Where can I get a Lakewood box fan repaired
You could repair it yourself or take it to a local electrical store or a vacuum repair shop. They are just a box, a motor and a switch. https://www.google.com/search?q=lakewood+fan+repairs ..
9/24/2023 5:35:42 PM • Lakewood Dryers • Answered on Sep 24, 2023
Where can i get a lakewood fan motor for lakewood fan model number HV-18
you would have to go to a place that sells motors and get one by motor type, that than the appliance make and model. All electric motors are standard by size, voltage, speed and fixings. https://www.google.com/search?q=lakewood+hv+18+replacement+parts ...
7/1/2022 6:03:50 PM • Lakewood Dryers • Answered on Jul 01, 2022
Need replacenent AC motor 110V 60Hz 1.7amps
google it
9/14/2021 11:53:56 PM • Lakewood Dryers • Answered on Sep 14, 2021
Mains Cord for Lakewood fan model LBF 2010A
Nothing specific to that fan, but they are all standard types. Pick the one that fits https://www.google.com/search?q=power+cord+types ..
6/30/2021 3:25:45 AM • Lakewood Dryers • Answered on Jun 30, 2021
Lakewood HV-18 Floor / Box Fan Logo
17 questions posted
Top Lakewood Dryers Experts
Jay Finke
Jay Finke
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lakewood Dryers
  • Lakewood Dryers
Most Popular Question
clean lakewood fan mine filthy
  • Dryers
