20 Most Recent HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0 Questions & Answers
2answers
I need another ac charge
You have to find them through HKC. Not even radio shack has the round end to replace a broken one. It's exclusive to HKC. Try searching for the charger in amazon or ebay. You need the model number, starts with P then a few numbers like 771A. Just know they are exclusive so you get the right one when you're searching and that the model number will help
12/15/2015 7:23:27 AM • HKC 7"... • Answered on Dec 15, 2015
HKC PROBLEM its Not Holding a Charge from wall charger or Charging to capacity
Time to change the battery
6/1/2015 6:07:27 AM • HKC 7"... • Answered on Jun 01, 2015
2answers
How can I fix my tablet
First make sure the tablet is charged up. Sometimes you just need to hold the power button down a little longer. If that does not work, most have a reset button that is recessed on the bottom edge of the tablet. You may need to get out the manual for the tablet to find the reset.
4/8/2015 6:06:32 AM • HKC 7"... • Answered on Apr 08, 2015
2answers
How can update my hkc tablet
I suppose you want to update to a higher Android version. I advise against it if you are a novice. First, you have to find an updated version of the ROM for your tablet specifically. Then, you will have to use an appropriate software to flash the ROM into your tablet. There is always a danger of bricking your tablet when flashing.
2/13/2015 7:12:38 AM • HKC 7"... • Answered on Feb 13, 2015
My HKC tablet keeps saying i am low on space...I onl have 5 games downloaded on it how can i get more space
You might just have to change your settings for your storage, move it to your card instead of internal storage
1/10/2015 12:11:45 AM • HKC 7"... • Answered on Jan 10, 2015
2answers
How to reset my hkc tablet
For and HKC 7" tablet there is no reset button however you can follow these steps to reset it first you power the device off completely next you hold down the power and volume up button simultaneously until the words HKC touch the wonderful world appears then you will release the power button only you will then find an android on its back you may release volume button then you will tap android or press power button to open the menu you use volume keys to scroll and power button to select scroll until you find wipe completely select that
1/1/2015 7:47:53 PM • HKC 7"... • Answered on Jan 01, 2015
2answers
Does this tablet have a camera facing the back instead of front pictures always
No. Tablet PC's, like notebooks only have one camera above the screen facing the user. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
12/3/2014 7:02:06 AM • HKC 7"... • Answered on Dec 03, 2014
2answers
Forgot password to get in tablet how do you reset it
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
12/3/2014 6:59:34 AM • HKC 7"... • Answered on Dec 03, 2014
How do i reset my hkc tablet model number p771a
This should do the trick, 1)Make sure the tablet is NOT connected to the charger 2) Power off the tablet by holding down the power button for about 10 seconds 3) Once it is off, hold down the HOME button and connect the charger while the button's being held down. 4) When you see the HKC logo come up, let go of the HOME button. 5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5. 6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again. 7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button. 8) Navigate to "Yes - delete all user data" and select it. 9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button 10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now" Dave
12/3/2014 6:56:31 AM • HKC 7"... • Answered on Dec 03, 2014
Hkc tablet problems
That foil part is your battery. The battery is dead and you need a new one. You would need the tablet cleaned up too.
12/1/2014 7:11:50 PM • HKC 7"... • Answered on Dec 01, 2014
2answers
My HKC A072D will not go past the initial HKC start up screen, at all, nothing has helped so far
This happened to my nieces HKC 7" Tablet and I held the Power button and the Home Button down for about 10 to 15 seconds and it reset everything and is still working to this day
10/31/2014 3:09:06 AM • HKC 7"... • Answered on Oct 31, 2014
How to factory reset a hkc tablet model number a072d
Try this 1.hold down the power key for 10 seconds to turn off the unit with nothing hooked to the unit (no ac/no usb/nothing) 2. hold the volume up key (+) and the power, once the screen starts to turn on release the keys. 3. NEXT you should get a robot laying down with a red triangle, push the power key one time. This will get you to the menu screen. 4. from here you chose the reset factory by using the volume down (-). Once you have that line highlighted press the power button. 5. next use the (-) key to get to yes to reset/reboot followed by the power key to chose the option. 6. tablet will come back on and be just like you got it from the store originally.
10/21/2014 10:35:35 AM • HKC 7"... • Answered on Oct 21, 2014
Need to reset. grandson loged
Hard reset, Press the volume up and power button for about 10-15 seconds to reboot. Wipe data/Factory reset.
9/26/2014 11:14:18 PM • HKC 7"... • Answered on Sep 26, 2014
Google play services has stopped workimg & locked up m hkc tablet
Try and delete then re install the app. If it's a system app just uninstall the updates. See if that gets google play working again. Reboot after you uninstall and see if that helps.
8/20/2014 7:21:19 PM • HKC 7"... • Answered on Aug 20, 2014
0answers
HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0 Logo
183 questions posted
Top HKC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a HKC Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • HKC Tablets & eReaders
Most Popular Question
tablet camera facing back instead front
  • Tablets & eReaders
