20 Most Recent GE GSS22JER Side by Side Refrigerator Questions & Answers
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
3/29/2015 1:20:44 AM • GE GSS22JER Side... • Answered on Mar 29, 2015
Same problem with our refrigerator - we have had
Try GE customer care at this number 1-800-437-3783. They are easier to get ahold of that way. Hope this helps.
3/21/2011 9:05:43 PM • GE GSS22JER Side... • Answered on Mar 21, 2011
Freezer cold but refridge is
sounds to me your fan is not working its in the freezer unit it blows cold air to your fridge if its turning ,,, defrost the whole unit ... sometimes ice builds up in the tunnel the air flows through . bsc appliances 07779933829 uk
2/27/2011 3:46:50 PM • GE GSS22JER Side... • Answered on Feb 27, 2011
The coils behind the freezer compartment freeze up
it can be,but before you replace that $100.00+ board,check the defrost heating element for continuity and also the defrost thermostat(both on the evaporator coil) as these go bad too and are much cheaper than the board
1/9/2011 2:34:57 PM • GE GSS22JER Side... • Answered on Jan 09, 2011
My refrigerator water dispenser stopped
Is the ice still dispensing? If you still are able to dispense ice then its possible that the water storage tank is frozen. The water tank is located in the back of the refrigerator section behind the crispers so they can sometimes freeze. You can try turning up the refrigerator section 1 setting warmer. If that doesn't fix it it's possible the solenoid for the water side on your inlet valve is bad.
10/7/2010 11:00:55 PM • GE GSS22JER Side... • Answered on Oct 07, 2010
FREEZER FREEZES OK BUT THEN IT WARMS UP TO MUCH
It sounds like the condenser is not getting proper airflow, I am assuming you've already turned the temp control to a colder setting
7/29/2010 6:48:36 PM • GE GSS22JER Side... • Answered on Jul 29, 2010
2answers
My freezer is cold, but my refrigerator is not.
CHECK THE EVAPORATOR FAN
5/6/2009 2:51:35 PM • GE GSS22JER Side... • Answered on May 06, 2009
GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
3/23/2009 2:38:53 PM • GE GSS22JER Side... • Answered on Mar 23, 2009
Icemaker
filter could be inside the refrigerator section upper right hand side. twist and pull down.
7/5/2008 3:25:01 PM • GE GSS22JER Side... • Answered on Jul 05, 2008
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps: Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle. Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker. Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located. Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail. Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment. Reinstalling the Tray: To reinstall the ice tray, follow these steps: Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails. As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails. Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back. Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this: Remove the ice tray. Close the freezer door. Press the dispenser for cubed or crushed ice; you should hear a snap. Open the door again and reinstall the ice tray. Remember to handle the ice tray carefully, especially if it's full of ice.
3/31/2024 9:43:28 PM • GE Refrigerators • Answered on Mar 31, 2024
2answers
GE GNE27JYMFS Energy Star 27.0 Cu. Ft. French-Door Refrigerator. How long does the Sabbath mode last on a GE GNE27JYMFS please.
Question edited for a lot more clarity. Question moved from GE Ranges to GE Fridges. Sabbath Mode stays on until you turn it off. Press and hold the Lock and Light button simultaneously for 3 seconds to enter and exit the Sabbath Mode.
Bottom Freezer Refrigerator - Setting Sabbath Mode
GE Appliances https://products.geappliances.com > appliance > gea-supp...
Explanation of the Sabbath Mode Feature
GE Appliances https://products.geappliances.com > appliance > gea-su... Refrigerators with a Sabbath Mode feature puts the refrigerator in a timed defrost mode. It also turns off the icemaker, dispenser, and control touch screens. ..
1/16/2024 12:53:20 PM • GE Refrigerators • Answered on Jan 16, 2024
How do you replace the temperature control board on a ZICS360NRCLH. I don't see any screws or anything that is holding it up. Your assistance would be greatly appreciated thank you. Chuck
The Technical Service Manual says it is help by 3 magic slotted fasteners! Plus some RTV 102 seal which is this
Momentive RTV102 Adhesive/Sealant rtv 102, 2.8 fl oz ...
RSHughes https://www.rshughes.com > rtv102_white_3tg Momentive white RTV102 adhesive/sealant with a 72 hr cure time. Provides a 20 min fixture time. Delivers great performance with a shear strength of 200 psi, ... US$7.84 · ‎In stock Service Manual Page 24 https://www.manualslib.com/manual/739574/Ge-Zic36on-Series.html?page=24#manual //
12/29/2023 2:51:58 AM • GE Refrigerators • Answered on Dec 29, 2023
GE GSS22JER Side by Side Refrigerator Logo
Popular Tags
21 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
ge side side gss22jerfww not keeping
  • Refrigerators
