20 Most Recent
Microsoft Surface 64GB Windows RT - with Touch Cover Black Questions & Answers
Software repair wizard
Write down all passwords you remember to have used lately and try them one by one. If that does not help, you only can reset the tablet and reinstall everything from scratch. You will lose all the data and all apps already installed. This time write down the password and keep it somewhere safe. (a place you don't forget)
7/15/2014 6:43:36 PM •
Microsoft...
Answered
on Jul 15, 2014
Battery location
I signed up for net gear but it is saying it will take a few minutes.now it is saying can't establish a reliable connection to the server
12/23/2013 1:39:11 AM •
Microsoft...
Answered
on Dec 23, 2013
Microsoft surface 3 charging
You should have had in the box with your Surface 3 Tablet a charger. It will have a plug with 2 points that is for your power plug, and at the other end you will have a natty little flat magnetised plug for the side of your Tablet. Mine is at the bottom right slot, looking at the screen of your Tablet. Now when the power is turned on, a small bright light will glow. That is now informing you that the battery in your Surface is being charged. Now at the bottom right of your Task bar, that is the Bar on the bottom of your screen where you can place program short cut Icons for your convenience. Now the speaker Icon which is there toward the right-hand side and has a cross if off, or a different look when on. Now the next icon on its right is the one that tells you how much charge is in the battery, if you touch it, it will come on to the screen informing you how much charge you have in the battery. If I'm using my Surface a lot and I do I keep it on charge while I work as a precaution to keeping my Surface well topped up. Hope this helps.
3/12/2019 10:14:08 PM •
Microsoft...
Answered
on Mar 12, 2019
I want to install Microsoft word on my ipad
Hi, you may have to go to the Microsoft home site, and ask for Microsoft Word or Office for iPad. There is one for both Apple and Android systems, but it is a little different to the one they have in their own Windows system. I use Open Source from Oracle it's free and it works well in my Windows 10 machine and Surface Tablet. Best of luck.
1/13/2019 12:09:56 AM •
Microsoft...
Answered
on Jan 13, 2019
Need to reset a digiland dl808w tablet NO TOUCHSCREEN
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
5/20/2018 4:22:31 AM •
Microsoft...
Answered
on May 20, 2018
WILL APPLE FIX MY IPAD AIR IF IT DOESNT CHARGE FOR FREE
Apple only fixes it's products for free during guarantee period (mostly 1 year, 2 years with Apple Care Protection Plan), but before you send it to Apple check your charger, you need at least a current of 2Amps. If this is ok, check if the charger can charge other devices. If yes, go to a store selling iPads and check if you can charge your iPad with the charger of one of the sample products.
8/12/2015 1:13:16 PM •
Microsoft...
Answered
on Aug 12, 2015
