My sincere apologies for the delayed response. I am personally going back to answer your unanswered questions. I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICKon the following LINK. It has the Belt Diagrams you will need. If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com! Again my apologies...
Remove the fan shroud because there just isn't enough room. The shroud is held on by clips on the top. Use a screw driver and pried them up. Shake the shroud around until it comes out, should be easy to do. Locate the belt tensioner, Drivers side of the motor, it's small and shiny.Use a 15mm on a ratchet with a long pipe used for leverage. To Remove Tension, push the pipe to the right (Drivers side) Remove your belt. Now for installation. Put the alternator on first, then the Idler and fan and Finlay the Tensioner. Left the PS, WP AND AC OFF Go under the car (jacked up the car for this part) and install the belt around the Crank Shaft (bottom pulley) This was very tight.Make sure the belt is installed correctly around the CS.* Once the Crank Shaft pully, Alternator and tensioner were on,put the belt over the AC pully. Back on top, Remove the tension and finish the job by installing the belt over the WP & PS. I hope this helps. The whole job should take about 30 mins.
am pascal Mbarubukeye as seen on my profile, i would like to ask for supporting me to offer serisl number of adobe audition 1.5, because what i have was corrupted. please help me i begg!
Adobe Communityhttps://community.adobe.com > ... > Discussions
Dec 7, 2018 - Solved: I've had to reinstall all applications after restoring Win10, and I have my CS2 Standard disks; installation itself went fine.
11 answers · Top answer: See here and use the new serial number you will be provided : Download Adobe Acrobat 7 and ...
You should never post such codes on an open forum, others may use it against your wishes. If you call Adobe, they will straighten out the issue for you if your codes are legitimately paid for.
