20 Most Recent
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Questions & Answers
Ceiling fans turn themselves on.
Hello :
I don't want to scare you . But when your fans turn themselves on , that means there's someone else at home . Why I'm saying that ? It seems that you have a problem in home electrical wiring connections . You need to make test . You can stay in the room where are the fans and send someone else the turn on switches at home one after another until you find which switch is turning the fans on . You need an Electrician to correct this error at home and to wibe ghosts out .
good luck .
rate please .
Hi. My name is Nivardo, I’m from México and
In the base of the lamp, cut the 2 wires coming in from the wall.
On one wire from the wall, connect it to the same wire going to the lamp (white wire, if you can tell which is which), AND the white wire from the Zing Ear (3 wires connected together).
For the other wire from the wall, connect it to the BLACK wire from the Zing Ear.
For the remaining wire to the lamp, connect it to the RED wire from the Zing Ear.
You also need to fasten the "TOUCH" wire from the zing ear to the frame of the lamp -- the metal part where you would touch the lamp.
That should do it.
Just put up the ansley
If you have a remote, change the frequency settings in the receiver & transmitter. If not a remote, Take the store brand fan back & get a good fan.
How to connect the motor
To what? If you're talking about the wiring it's; Black to black White to white Blue to red ( If no red in ceiling wiring then put black & blue from fan to black in ceiling ) Green to green or copper wire.
