20 Most Recent
Internet CA Security Suite Plus 2009 for PC Questions & Answers
Will not connect to internet
If your device isn't connecting to the internet, try restarting your router or checking your Wi-Fi settings. Sometimes, a simple reset can fix connectivity issues. If the problem persists, there might be an issue with your device's network settings or hardware.
3/11/2024 9:03:06 PM •
Internet...
Answered
on Mar 11, 2024
My MCA-66 6 Zone, 6 Source Controller Amplifier does not stop searching after an internet connection is made.
If you have a wireless connection, use your phone to check the router signal strength at the antenna for the controller gateway (power down the gateway so it doesn't interfere with the phone's measurement). If the signal strength is below the third arc, move the gateway to a better location. Also check your phone's connection performance while holding it at that point. Even if you have good signal strength, reflections may be causing high signal error rates.
Common causes of such issues are shading by HVAC ducts, metal appliances or furniture, or even the metal cases of nearby audio equipment. The metal can also act as a mirror and bounce a delayed signal to the wireless antenna that interferes with the direct signal. The fix is to move the antenna or the household router, rearrange the equipment to get a clear "view" of the router (keeping in mind where the ducts go through the walls, floors or ceilings), or install a wireless repeater and set the controller gateway to the repeater channel. Nearby microwave ovens can interfere with some wireless channels when they are running, so that's another possibility.
If all else fails, you can use a wired Ethernet connection to bypass the wireless connection problem. You should still be able to use your phone app because it works through the network router, not directly to the audio controller. You may need to redo the connection settings if go wired or install a repeater.
2/5/2024 3:41:47 PM •
Internet...
Answered
on Feb 05, 2024
My Internet connection is working on everything on my iPad but I still can't get big fish casino to load. It keeps saying retry. What do I do?
- Restart the app: Double-tap the home button and swipe up on the Big Fish Casino app to close it. Then, open the app again.
- Restart your device: Press and hold the power button until the "slide to power off" appears. Slide the bar to turn off the device. Once it's off, press and hold the power button to turn it back on.
- Clear the app cache: Go to Settings > General > iPad Storage > Big Fish Casino. Tap "Offload App" and then confirm. This will clear the app cache without deleting any app data.
- Check for updates: Go to the App Store and check if there are any updates available for Big Fish Casino. If there is an update, download and install it.
- Contact Big Fish Casino support: If none of the above solutions work, contact the app support team to see if they can help you resolve the issue.
2/4/2024 5:01:45 PM •
Internet...
Answered
on Feb 04, 2024
Radio internet wifi Sweex MM220 waiting for P wizard
It seems like you're having an issue with your Sweex MM220 internet radio, and you're waiting for a setup wizard (P wizard). To set up the radio, it's possible that you need to follow a setup wizard provided by Sweex or configure it using a web interface. Check the user manual or Sweex's official website for specific instructions on how to set up your radio with an internet connection. If you encounter any issues during the setup, consider reaching out to Sweex customer support for further assistance.
10/29/2023 5:19:48 AM •
Internet...
Answered
on Oct 29, 2023
Acorn Stairlift armrest switch not working, what to do?
If one of the armrest switches on your Acorn Stairlift is not working, there are a few possible causes and solutions. Here are a few steps you can try to troubleshoot the issue:
- Check the wiring: If the armrest switch is not working, it is possible that the wiring for the switch may have become loose or damaged. To access the wiring, you will need to remove the armrest. To do this, first remove the armrest cover by removing the screws that hold it in place. Then, carefully disconnect the wiring for the switch and check for any loose or damaged connections.
- Check the switch: If the wiring for the switch is in good condition, the problem may be with the switch itself. To access the switch, you will need to remove the armrest. Once the armrest is removed, you can test the switch with a multimeter to see if it is functioning properly. If the switch is faulty, it will need to be replaced.
- Contact Acorn Stairlifts: If you are unable to diagnose or repair the problem with the armrest switch, it is best to contact Acorn Stairlifts for assistance. They should be able to provide you with specific instructions and guidance for removing the armrest and repairing the switch.
I hope these steps help to resolve the issue with your Acorn Stairlift armrest switch. If you need further assistance, it is best to contact Acorn Stairlifts for support.
10/6/2023 6:58:42 AM •
Internet...
Answered
on Oct 06, 2023
CATLINK SCOOPER PRO - how to get fully connected to my internet
Here are some steps to troubleshoot this issue
- Make sure your Catlink Scooper Pro is within the range of your Wi-Fi router.
- Double-check that you are entering the correct Wi-Fi network name (SSID) and password during the setup process.
- Restart your Catlink Scooper Pro and your Wi-Fi router to refresh the connections.
- Ensure that your Wi-Fi router is using a 2.4GHz band, as some devices might not be compatible with 5GHz networks.
- Check if there are any firmware updates available for the Catlink Scooper Pro that could potentially resolve the connectivity issue.
- If possible, try setting up the device using a different smartphone or tablet to rule out any compatibility issues with the app.
If the problem persists after trying these steps, you might want to reach out to the manufacturer's customer support for further assistance with the specific device setup. They should be able to provide you with more detailed guidance and troubleshooting steps tailored to your device and app version.
8/6/2023 7:16:41 AM •
Internet...
Answered
on Aug 06, 2023
How do I set an Alexa up with new internet settings
Update the Wi-Fi Settings for Your Echo Device
- Open the Alexa App .
- Select Devices .
- Select Echo & Alexa.
- Select your device.
- Select Change next to Wi-Fi Network and follow the instructions in the app.
8/1/2023 6:35:00 PM •
Internet...
Answered
on Aug 01, 2023
