20 Most Recent GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW Questions & Answers
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
GE Profile 26.6... | Answered on Nov 20, 2019
Filter housing probably has a cracked or bent o-ring. Put some food grade lubricant around the o-ring. If that does not help, replace the o-ring.
GE Profile 26.6... | Answered on Mar 28, 2018
The foam in the freezer door has deteriorated and will need to be replaced, that is the door will need to be replaced.
GE Profile 26.6... | Answered on Jan 01, 2018
If it has a filter on the bottom, make sure that is clean.
GE Profile 26.6... | Answered on Dec 22, 2017
Theory of operation: Cold air is produced in the freezer section and is then circulated via a fan located in the freezer section. It sounds like you may have either an air leak from faulty door seals, ice dispenser door flap stuck in the open position, or the light staying on the door is closed.
A faulty compressor fan may also cause symptoms like that but you should hear the thermal cut out clicking off and on due overheating of the compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
GE Profile 26.6... | Answered on Oct 10, 2017
You are correct -Temps not low enough and you have been thorough in checking things out. About the only thing I can think of now is to make sure that the condenser coils underneath are perfectly clean to promote max efficiency. If clean, and we know your compressor is running after all these years You may be, yipes, low on refrigerant. I am sure you have thought of that but did not really want to deal with it - don't blame you. If you want to pursue that venue it is a PIA but can be done, CAREFULLY because the freon level on refrigerators is a critical parameter, not like a room or car AC. If wanna try relist your question as DIY refrigerator charging.
GE Profile 26.6... | Answered on Sep 02, 2017
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
GE Profile 26.6... | Answered on Apr 19, 2017
Looks like you're having a problem with the s
GE Profile 26.6... | Answered on Apr 02, 2017
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
GE Profile 26.6... | Answered on Apr 01, 2017
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
GE Profile 26.6... | Answered on Dec 24, 2016
call a service repair site it probably needs freon added or more help
GE Profile 26.6... | Answered on Oct 16, 2016
Check for ice on back wall of freezer. If there then the self defrosting mechanism is not working. If all systems are go then check for leaking door gasket, bad thermostat , and low gas situation.
GE Profile 26.6... | Answered on Mar 11, 2016
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
GE Profile 26.6... | Answered on Oct 26, 2015
Most likely the=> Defrost Heater Assembly WR51X10055 and High Limit Thermostat WR50X10069 need to be replaced. Heater is burned out. High Limit Thermostat WR50X10069
Appliance 911 Sea Breeze
GE Profile 26.6... | Answered on Sep 02, 2015
Refrigerators Logo
763 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
frg works frez getting warm
  • Refrigerators
