You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to: Click start right click on my computer select open Right click the icon of your Flash Drive (It should be F:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
Windows Advanced Options Menu
Please select an option:
Safe ModeSafe Mode with NetworkingSafe Mode with Command Prompt
Enable Boot LoggingEnable VGA modeLast Known Good Configuration (your most recent settings that worked)Directory Services Restore Mode (Windows domain controllers only)Debugging Mode
Start Windows NormallyRebootReturn to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
1 questions posted
19,138 Questions
12,216 Questions
7,310 Questions
7,277 Questions
5,472 Questions
