20 Most Recent
GE GSS25JEM Side by Side Refrigerator Questions & Answers
I have a GE Refrigerator
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker Refrigerator Parts
Gss25jemc defroster not working
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Freezer is frosting
Even frost free freezers will frost up in high humidity, especially if there is a poor door seal. Defrost the freezer by turning it of and placing pans of hot tap water in the freezer. You can speed this along by helping to remove the ice as it melts. Check the door seal after you've defrosted the freezer, a bad seal is one of the big causes of frosting up the next biggest problem is usually holding the door open.
If it's a frost free unit, if the problem continues you'll need to have it checked out.
I have a GE model #dss25pfmd ww and it stopped cooling
FIRST WE YOU NEED TO MAKE SURE YOUR COMPRESSOR STILL GOOD OR NOT. THERE'S A 3-N-1 BOOSTER YOU CAN GET AT LOCAL APPLIANCE PARTS STORE. YOU CONNECT THAT TO COMPRESSOR AND IF IT RUNS GOOD. THEN YOU HAVE A BAD CONTROL BOARD(WHICH IS RIGHT THERE BEHIND THE METAL PLATE).
[email protected] OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Refrigerator not defrosting
Normally, the defrost heater can be checked for continuity rather than ohms of resistance. If the heater is o.k., then your problem may be the defrost thermostat or defrost timer. Contact an appliance service company.
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the
water supply comes in can have a slow leak and will cause ice to buildup and
block the fill tube. Disconnect the ice maker line from the valve and watch to
see if it has a slow drip. It doesn’t take much to eventually block the fill
tube.
