20 Most Recent
Dayton E52 Utility Heater Questions & Answers
Dayton mod#3e219b gas heater
air compressor output should be 3.5 psi. to the fuel nozzle. the cowlings purpose is to channel the air-fan output through the rear vanes of the combustion chamber. if these openings are restricted then air can't get into the chamber. check to see that the fan blades aren't jammed against the cowling. if they won't spin then you won't get any air through the unit.
Nasfan1@mailcity i have a
I am not truly sure but I believe some of those Herman Nelsons that use liquid fuel must be set flat or it wont light also I believe it may have a safety bypass button for lighting
No fuel pick up
Hi and welcome to FixYa, I am Kelly
No fuel pick up is caused usually by cracked fuel lines or... a fuel tank cap that is not closed completely or not properly vented. It can be the pump or a clogged fuel nozzle or fuel filter.
Here is a manual that will help you sort it out:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual has all the information you will need to get it going again. Even without the "test equipment" listed in the manual.
Thanks for choosing FixYa,
Kelly
110,000btu comes on runs 3
There could be several reasons for this problem. I can offer a few things to check. First check the filters mainly the exhaust filter under the black plastic cover on the back of the pump. If that is dirty mainly the gray side with the gasket that contacts the pump housing. If it is dirty use compressed air to blow off the dirt from the surface. This will be just temperary to rule it out it will probably need replacing. Reassemble and try starting again. The pump pressure should be checked and adjusted if needed. It should be about 4.5 psi. if it is not close within 1/2 to 1 psi. it will need to be adjusted accordingly. There is still more but it would require more time and some explaination so if this does not work we should talk. I will check back in a couple of days.
Shoot kerosene when trying to start
You need to either clean your nozzle assembly or replace it.Cleaning it can be done as follows, you need carb cleaner Q-tip and a tooth pick. First soak the nozzle in carb cleaner, then use the tooth pick to remove any obvious large pieces of what ever just do not damage the front of the nozzle the Q- tip is for cleaning all the exterior surfaces. Now that you have gone this far you need a compressor and an air gun to blow high pressure air backwards and forwards thru the nozzle this should clean it out. On older models they have a screen assembly behind the nozzle if yours does clean it as these corrode while in storage. Put the assembly back together and test nozzles atomize the fuel (fog) not spray, so watch carefully if it sprays fuel you need to replace the nozzle, pay attention to the spray angle and GPH rating printed on the side of the nozzle it is very important when purchasing a new one that you buy the exact same rated nozzle. Good Luck
I have a dayton 3VG79B
Goto
www.desatech.com
Look under construction heaters for you model # and it will show you a parts diagram. Get your part # and there should be a link on the home page to order parts. You can also go to a local Grainger Industrial Supply and order one or call them and order it.
Dayton e51 kerosene heater
We have a 3VE53C 400,000 btu heater , the fans will come on you can hear the ignitor and fuel will run out of the front of the unit. It trys to fire twice and will not. Then you get the E1 error sign.
