20 Most Recent
GE 30 in. Profile JGP989 Gas Cooktop Questions & Answers
I have a GE Profile 30" Ceran Schot cooktop mottle
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
10/2/2017 12:14:29 PM •
GE 30 in....
Answered
on Oct 02, 2017
I have a GE Profile
I don't think that it is burned into the glass ..cause it is made specially for high temperatures..I would remove the glass ..and place it in a large pot ..with caustic soda ..there is available on the detergents department....but pay attention on hands cause ..this stuff burns the flash into soap ..its like the sulfuric acid....
and some detergent too..and boil it at a low flame ..for about half an hour..and it will clean up nicely ..
9/1/2010 2:49:49 AM •
GE 30 in....
Answered
on Sep 01, 2010
I have a similar problem with my GE Profile stove
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
8/19/2009 12:05:42 AM •
GE 30 in....
Answered
on Aug 19, 2009
Ignighter issues
gud day,try to clean the area wer the knob place by using vaccium try to remove the knob then claen by vaccium,coz the dirt inside coz of grounding.
3/24/2009 12:22:24 AM •
GE 30 in....
Answered
on Mar 24, 2009
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM •
GE Cooktops
Answered
on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM •
GE Cooktops
Answered
on Nov 01, 2020
Ge monogram induction cooktop error F
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
1/9/2019 10:31:53 PM •
GE Cooktops
Answered
on Jan 09, 2019
