20 Most Recent GE 30 in. JGP336 Gas Cooktop Questions & Answers
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
GE 30 in. JGP336... | Answered on Aug 07, 2014
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
GE 30 in. JGP336... | Answered on Jul 23, 2014
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
GE 30 in. JGP336... | Answered on Feb 17, 2014
on mine I just pull up on front egde and it will raise. There is an arm that will catch to hold it up while cleaning.
GE 30 in. JGP336... | Answered on Jul 26, 2012
Hi mikegou100,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
GE 30 in. JGP336... | Answered on Aug 03, 2011
Usually, the igniter is contained in the same switch ( control knob) as the gas flow. When you turn it on, you should hear a clicking noise. I've never seen one of these with a separate ignition system. Sorry if that's not the problem tokfm
GE 30 in. JGP336... | Answered on Jan 11, 2011
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
GE 30 in. JGP336... | Answered on Oct 10, 2010
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
b,bm
GE 30 in. JGP336... | Answered on Sep 30, 2010
heatman101
erty3
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
GE 30 in. JGP336... | Answered on Aug 30, 2010
GE 30 in. JGP336 Gas Cooktop Logo
70 questions posted
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
raise cooktop
  • Cooktops
