GE Cooktops • Uploaded on Sep 23, 2013
The light what we call sparking is produced by a MODULE SPARK Part Number: AP3993727 made by GE, item no 318, This module by turning any of your Knobs item no 29 it produce the sparking by a switch which is connecting the wiring of the VALVE GAS Part Number: AP3994025 made by GE, item no 314 to the above MODULE SPARK.
So either the switch attached to the GAS VALVE is stuck on (sometimes this happen after some water spillage over the knob, or just by long time use. In this case you have to remove the two wires on the valve you have the e sparking always on if the sparking goes OFF then replace this valve switch. If you still have the sparking then you need a new SPARK MODULE.
You can reach all parts mention above by removing all burners complete, bases, heads, lids and then lift up the MAINTOP.
Here below we have the link with all above mention parts and all the part layout of your stove which will help you find the parts mention and even order them if you like.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203210&diagram_id=25791125
22 questions posted
136 Questions
43 Questions
45 Questions
50 Questions
27 Questions
