20 Most Recent
Polaris 2004 EDGE Touring 340 Questions & Answers
I have a polaris 340 edge touring it cuts out on 1 cylinder idiling and when it slows down on grades and in deep snow
I believe you are going to find out that your PTO Cylinder has lost compression and when it gets under load, it is not able to function properly. Do a Compression Test and you will find that the PTO Cylinder is going to be well below 90 and your Recoil is going to be right around 110-120. The Repair is not difficult and only takes 4 hours when you get rings installed. I would also recommend that you purchase a new piston with rings, normally you are going to see Piston Slap on the Walls that will prolong the life of the Engine if you do it right the first time.
Polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Polaris 600 iq overheating
Either you have a Blockage in your Cooling system, you are not getting enough snow onto your Heat Exchanger or you have a blown head gasket. Is exhaust into your Cooling Bottle?
I have a 1995 Polaris Indy 500. The engine floods
SOUNDS LIKE WOUR NEEDLES ARE STUCH OPEN. A CARB REBUILD IT GOING TO BE NEEDED. TO GET IT UN FLOODED, REMOVE THE SPARK PLUGS AND TURN THE GAS OFF. THAN START PULLING IT OVER. U CAN ALSO LET IT SIT WITH THE PLUGS OUT FOR A DAY OR TWO AND LET THE GAS EVEPORATE, MAKE SURE THE FUEL IS SHUT OFF THOUGH
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
