20 Most Recent
Polaris 2005 Classic 550 Questions & Answers
2005 polaris 550 classic left cylinder not firing
Hopefully it's just the spark plug, take it out and check the gap and coloring, clean it and set the gap to the recommended gap, Or take note of the spark plug code and get a new one, check with the manufacturer or in your handbook that it is in fact the correct one.
Check the connections and lead, they do deteriorate over time, to find out if your on the right track, swap the leads over and see if the other cylinder dose the same thing. Swap the spark plug over from the other cylinder for process of elimination. So if it's still missing we know to check the pickups or cdi unit, there's a possibility its fuel, check the carburetor, is it a twin carb? If so, clean it buy taking the bowl of and draining out the fuel, you should do this occasionally anyway. Check the fuel filter while you're at it.
Good luck
Polaris 600 iq overheating
Either you have a Blockage in your Cooling system, you are not getting enough snow onto your Heat Exchanger or you have a blown head gasket. Is exhaust into your Cooling Bottle?
I have a 1995 Polaris Indy 500. The engine floods
SOUNDS LIKE WOUR NEEDLES ARE STUCH OPEN. A CARB REBUILD IT GOING TO BE NEEDED. TO GET IT UN FLOODED, REMOVE THE SPARK PLUGS AND TURN THE GAS OFF. THAN START PULLING IT OVER. U CAN ALSO LET IT SIT WITH THE PLUGS OUT FOR A DAY OR TWO AND LET THE GAS EVEPORATE, MAKE SURE THE FUEL IS SHUT OFF THOUGH
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
